Not that anyone cares about my car, but in the interest of keeping track of this shit somewhere;
- this week = new motorcraft plugs, new blue streak distributor cap and rotor. runs great.
- tomorrow = KYB GR-2s installed to replace 20 year old OEM shocks, front brakes serviced, wheel bearings and etc replaced, oil change.
Have a slow leak on my drivers side rear axle. Not enough to write home about but it's only going to get worse, and definitely not better.
Before learning about this axle seal leak, I had purchased a camshaft from a 1994 Cobra from a guy on corral, as well as a Lincoln mk VII ECU and 19lb injectors from 85crownHPP. New trunk emblem is on the way from monterey. The HO stuff will all go on at the same time and will be accompanied by the usual front-of-the-motor gubbins - harmonic balancer, timing set, water pump.
The HO swap honestly started out because I need valve cover gaskets and figured I'd replace the intake/tb while they were off...my injectors are sketchy, it wouldn't be too much more trouble to replace those...no sense in buying new 14lbers so I might as well get the HO injectors. Well, If I do that, I'll need a new cam and computer...not too much extra work to pull the lower off.
car guy justification ftw
