yep, just splice the ground wire for the parking light into the flasher wire (green on my car) going to the turn signal bulb. That's it. I just snipped off the ground wire and ran a wire from it to the green wire, and that was the result.
85 351 4door Vic **DUW**
Nasty weather and family functions have been putting the kaibosh on further work on the car. All I've really done is clean up the whitewalls (looks nice to finally have 4 fresh white walls) and fixed my rear defroster with a neato kit from Canadian Tire. Oh yeah, and undercoated the ass out of everything, including large portions of my hands and face.
The car seems to actually be warming up more quickly now, which is strange given the temperature has hovered around freezing lately. Whatever, I won't look a gift horse in the mouth.
I just picked up a wiring harness which SHOULD allow me to finally hook up my dad's 3-4 year old Pioneer head unit.
I also got some Champion copper plugs (RV17YC), which brings me to my next questions: Before I completely narf up my heads, are these the correct plugs for my 351, and what should my gaps be with a 192 degree thermostat and average timing? Speaking of which, I need to call a man about a light...
Pics when it clears up, hopefully.Last edited by johnunit; 12-09-2009, 05:52 PM.
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Not sure about the model of spark plug you're using, but if a parts store sold them to you based on the application of an '85 CV with a 351, you should be fine. I always set gaps to about 0.050".
yeah, it was down as being correct for a 5.8L crown vic in the reference book for spark plugs, but I've had issues with those books being off in the past, most notably a fuel filter that I still haven't found the application of. It sure as hell doesn't go in the front of a 7200 VV.
Thanks, I shall gap dem tingz.
lol yeah, I learned that the hard way.
What a fun thread to read!
I remember when I was young and still had all that automotive enthusiasm...Last edited by Ike Clanton; 12-10-2009, 04:02 AM.
Originally posted by Nathan in MI View PostNot sure about the model of spark plug you're using, but if a parts store sold them to you based on the application of an '85 CV with a 351, you should be fine. I always set gaps to about 0.050".2012 Mazda5 Touring | Finally working on the LTD again!
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Yes, that would be correct, so assuming his car is stock it would have the E5AE heads.
I won two ebay auctions today
one for an NOS Motorcraft rebuild kit and one for a 38 page ford manual on VV carbs. The parts are piling up, and now it's too damned cold and dark to get any work done on the car... Oh well.
Off the top of my head I have parts in hand (or in the mail) to do the following that needs doing:
left reverse light
antifreeze flush/refill+ thermostat
carb rebuild
brake bleeding
plugs
new head unit and rear speakers
more undercoating
new valve stems (at least one tire has slow leak)
adjust rear brakes (locking up far before fronts)
and on and on it goes...Last edited by johnunit; 12-10-2009, 05:54 PM.
Originally posted by Nathan in MI View PostYes, that would be correct, so assuming his car is stock it would have the E5AE heads.
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
E5AE castings flow pretty similarly to E7TE castings. The main difference is that the combustion chamber is slightly bigger, so you would get a slight increase in compression with the E7's. Enough to make it worthwhile? Not really. I'd say that saving up for a set of GT40s or GT40Ps is a good idea.
good to know.
Any idea what my compression ratio would be with unshaved GT40P's?
I installed a newer pioneer head unit this week. The sound is a bit better, but two of the speakers still don't work. Now I have to figure out what the hell is wrong with the wiring. Same problem, two head units and harnesses.
The carb rebuild kit came today. It's a genuine motorcraft kit, unopened, with all the stuff I could ask for. Only 14 dollars to my door. The one thing that's annoying me is I don't know any way to re-build or even diagnose the choke mechanism. I have a feeling that it not working is the reason behind the long warm ups (2+ minutes of feathering the throttle or it stalls), but it may just be the general out-of-tuneness of the carb or the vacuum leaks that I'm slowly tracking down.
Also, work told me "see-ya in february" today. That wasn't totally unexpected, but it'll make scraping by the next two months interesting. At least I have lots of stuff to do to Sophie in the mean time.
