Yikes, this was on the 3rd page? That's not right.
I got a nice shipment from Rockauto a while back.
Speedo cable, calipers (actually from canadian Tire, took a month for the right calipers to come in), pads, u-joints, bearings, intake gaskets.
I screwed up and only bought one each of the inner and outter wheel bearings. Once I fix that (hopefully this week) I'll be throwing on the pads, bearings, speedo cable, and previously purchased rotors. Also on the list is finally getting summer tires on. Burnoutfest with the old winters maybe?
The intake gasket set is probably going to be used when I finally get my hands on the variable venturi tools and rebuild the carb. I'm going to pull the intake and do some mild home porting on it, and maybe gasket-match the runners on the heads. I know porting is sort of considered a "best left to the experts" thing, but I figure if I use un-aggressive bits and don't go greedy, there has to be some improvements on such a low-performance manifold without narfing things up.
I also spent about 8 hours under the car scraping off almost all the undercoating that was covering rust, and then coating the rust in rustoleum semi-gloss black. I'll do the other side at some time, and finish off painting the rear axle.
I found a pleasant surprise under there in the form of newly (2-3 years) replaced brake lines and a section of both fuel lines.
Enough positive, now some negative:
The gauge pack and a few other things are on hold, as I still haven't nailed down a summer job. This is also putting my attendance at Scottfest (300+ bucks in gas + contributions to the food/preparations) in jeopardy.
I found a nasty hole in the trunk pan, near the front passenger side. There was a hole under the rusted out area, opening onto a boxed-in area about 2 by 7 inches. I'm not sure what purpose it serves, and why there was no plug there (or in it's twin hole on the driver's side), but it sure did a good job of holding sand and salt in there and rotting a bigass hole.
Preliminary plan is to cut out the nasty rust, which doesn't seem to go beyond the metal covering the aformentioned box, fill up the entire hole with fiberglass (yeah it's overkill, but why not?) and then put sheet metal in place over the hole using more fiberglass as a glue and sealant.
Does the hump/dome to the left of the hole serve any purpose? It seems to just be a random lump, but I want to know if it "does" anything before I just roughly pound the shape into the patch panel. I know just fibreglassing it in is sort of hacking it, but I don't have access to a welder. Is there any way to get access to the boxes beside the one with the hole for rivetting or rustproofing?
Also, am I right in assuming this UCA bushing is thoroughly shot? yes those lines are cracks.
