View Post
Originally posted by 87gtVIC View PostAny thoughts on my idea of having a smaller pulley making it easier on the voltage regulator taking in consideration the fact that I have a crank underdrive pulley installed? Sane, insane?
I have a small "power & amp" pulley on the 80 Capri w/"race" underdrive crank pulley just to keep the batt charged LOL
The reg doesn't really get stressed, but the alternator has to spin at a certain rpm to make full output power. If you're at normal charging voltage at idle with the headlights, blower, and all the other stuff that is usually turned on running, honestly I wouldn't worry about it. Mine went on in an effort to make up for voltage loss problems I had with the electric fan. The idea was that if the alt spun a little faster, maybe the headlights wouldn't dim so much at idle when the fan was running. It did help, but putting the clutch fan back on helped more. I'm also running the crank underdrive.
Spacers are basically washers, only thing remotely special about it is how thick the thing is. If its some odd dimension that isn't what a washer or two stacks up to be then its special.86 Lincoln Town Car (Galactica).
Everything here works fine and I have no electric fail..I mean fan to worry about.
Im not going to sweat it.~David~
An alternative option would be to pick up a 3G pulley for a '97 Ford Escort (Motorcraft GP-712). It's nearly identical in side to our stock 2G pulley. I have one I'm planning to use on my car once I get around to swapping in the 3G.
—John
1985 Ford F-150 XLT Lariat
Hmm. New options. cool.~David~
Originally posted by Giraffe View PostAn alternative option would be to pick up a 3G pulley for a '97 Ford Escort (Motorcraft GP-712). It's nearly identical in side to our stock 2G pulley. I have one I'm planning to use on my car once I get around to swapping in the 3G.
https://www.rockauto.com/en/parts/mo...or+pulley,2448
So. Dad had an order for rock auto and it happened to have a shared shipper location so I picked up the pulley mentioned above and it is just a bit larger in size as compared to the stock 2g set up.
3g on the left of screen and stock panther 2g on right:
New GP-712 on left of screen and stock panther 2g on right:
new GP-712 on left of screen and stock panther 2g on right:
I haven't installed anything....winter project as nothing is urgent/necessary.~David~
How's the depth on that pulley? Will it seat in the same position as the 3g/2g pulleys?
That pulley is the factory 3G pulley you would find on a 1997 Ford Escort. I know of at least one Mustang guy on another forum who is running that pulley without issue (that's where I got the idea).—John
Originally posted by sly View PostHow's the depth on that pulley? Will it seat in the same position as the 3g/2g pulleys?
Originally posted by Giraffe View PostThat pulley is the factory 3G pulley you would find on a 1997 Ford Escort. I know of at least one Mustang guy on another forum who is running that pulley without issue (that's where I got the idea).~David~
The AOD sound is so great that you should totally consider keeping it and selling me all your manual transmission conversion goodies haha.
You car does sound good especially in the mid range like when you passed an newish F150 in the video.1990 Country Squire - under restoration
The AOD whine reminds me of school busses when I was a kid. Not sure what they used, but they were a very whiny and clunky automatic.86 Lincoln Town Car (Galactica).
Originally posted by Tiggie View PostThe AOD sound is so great that you should totally consider keeping it and selling me all your manual transmission conversion goodies haha
How much do you want for it? LOL
It does sound vicious, I like the tire chirps in second!
