Originally posted by 87gtVIC
View Post
Today was a very productive day.
Back when I went for the first drive with the new engine the car came down with an alternator charge issue. Poked around a bit to discover that the red and green wire at the voltage regulator was not receiving 12v power when in run/start. Poo. That is a problem.
My car no longer has the in-dash battery light so years back when I did all of this I just grabbed an unused 12v in run/start that I found underneath the hood. My 12vdc alternator turn on wire now originates at fuse 18 protected by a 10amper.
Opened up the EVTM and look and try to find what the hell is going on. Every time we put a new fuse in and turn the key it immediately blows the fuse. DEAD SHORT. But where.
Dad and I pull seatbelt warning and other things on the circuit. Dad being dad also tried a bigger fuse 15amp. It blew too!
Anyways after awhile we put a 10amp fuse in and turn the key and all is well. No issues. So I button everything up and go on my way with other things just chalking it up to something underneath the dash shorting out while driving from bouncing around and such. NOT a comfortable feeling so I was going to make a wire handy to provide the "turn on" wire 12v incase the primary one died again.
Go out for drive number two with the new combo and notice my fog lamps are not working.
Mid-drive of drive one I turned the fog lamps on but never looked if they were actually on, or if the indicator for them illuminated. At the end of drive two I add “fix fog lamps” to the list of things to get done.
Now today I got to dig into everything. I pull the fuse panel cover and find the source of the fog lamps power and find it jammed into some female spade next to fuse 18 mentioned above. I then pull the fog lamp switch and find that the 15amp fuse is blown for it. I replace it and turn on the fog lamps. IMMEDIATELY fuse 18 blows its 10amp fuse.
BINGO. Now I now what is going on.
Appears as if the fog lamps are getting power from the same circuit somehow!
I start digging under the hood and find the fog lamps power wire. There is a male and female spade connector in the path. I break it and see if I can power the fog lamps up locally with my power probe. I go to do so and the power probes CB trips and says “internal CB resetting.” Perfect.
Continue following the fog lamps power wire to find it completely pinched and dead shorted to ground underneath the 8mm bolt that holds the inner fender to the fender from the wheel well. This must have happened when I removed the inner fender over winter to replace the computer and install the new brake booster.
Fix that shorted wire and button up the fuse panel with a new 10amp fuse in slot 18 and screw the fog lamp switch back in. Fixed.
So the female spade next to fuse 18 is C301. Somehow that ties into the low fuel warning light which also was not working when fuse 18 blew.
I plan to relay the fog lights as I don’t like its full power originating from this location.
Just happy I don’t need to worry about the alternator quitting on my and leaving me stranded anywhere.
In other news I looked under the hood and the catch can is working like a boss.
![](http://i947.photobucket.com/albums/ad313/buergermeisterd/My%20car/image_12.jpeg)
Now another thing that has been bothering me is the front addco sway bar. It is the 1 ¼ bar that was made too long so your tires rub when almost at full lock. I think Zach mentioned how this was an issue for many people including himself.
So to remedy this I took to the junkyards in search of a big bar from a 1998-2002 Panther since I have the 1998-2002 spindles to accommodate this style of sway bar. I ended up not only getting a 28.5mm bar which equates to 1 1/8” (just an 1/8” smaller than the addco at 1 1/4") but also figured that I will just take the frame mounts and adapt them to my own frame because its' holes are stripped out in the frame already.
So I made a template with my list and dirty hands and then set it in stone with the sharpie:
![](http://i947.photobucket.com/albums/ad313/buergermeisterd/My%20car/image_16.jpeg)
Back home I cut it out and transferred it to a piece of aluminum to make a template and give myself an idea as to what will be involved in making this happen.
![](http://i947.photobucket.com/albums/ad313/buergermeisterd/My%20car/image_13.jpeg)
![](http://i947.photobucket.com/albums/ad313/buergermeisterd/My%20car/image_14.jpeg)
(this was a piece of road sign I took from Cleveland back in 2012 I believe)
![](http://i947.photobucket.com/albums/ad313/buergermeisterd/My%20car/image_15.jpeg)
Was easy to fab up and will be mega easy to remove and the install sway bar in the future!
Now I just have to order endlinks, bushings and make the frame accept this style of fastener.
