more of a new Ford blue fan myself. The dark just isn't my favorite color. Proper color for our cars was probably grey, which I think is a horribly boring color.
I like the blue. That's THE ONLY good Ford blue. The rest are absolutely ugly.
Good work champ, maybe this will be able to end with burnouts.__________________________________________________
Put engine clear coat on it, make that shit as thick as you can, so you can just hose it off and it protects the blue.__________________________________________________
Originally posted by Bobcat View Post...Burnouts...?
[QUOTE=sly;763292]I have video of him putting down 2 stripes during the cruise. It will get posted by the end of the weekend.[/QU
LIVE ACTION!__________________________________________________
Woot~David~
Pulled the HO cam from the Late Model Block and installed the trickflow stage 1 stick. Slipped on the ford racing timing set and had pretty much ZERO camshaft end play. Spent this afternoon sanding down the thrust plate to achieve the proper end play.
The new and HO
The thrustplate in work:
And the results:
We've got the same cam.
We're like brothers.
Long lost brothers.__________________________________________________
You two should do burn outs together......2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
It's coming along mang. Good to see.
Originally posted by 88Vic View PostI see both you and your dad think you're Freiburger, working on the car in sandals.
