    took 3 days
      Painted Fender Supports
      Painted up my fender supports yesterday as I had some free time to do so. I sanded them down, primed with engine primer and painted with aluminum engine paint and cleared with engine clear. They came out nice. I also did the hardware with rusty metal primer, engine low gloss black and engine clear. I will install these after I receive a transmission cooler and install that along with my power steering cooler as I have to remove the air box to do so and the braces prevent me from doing so. While the air box is out I will also paint the hardware that secures the box to the inner fender with aluminum engine paint.
      The whole deal
      Hardware
      Braces
      Just kiddin'
      Fender braces
      Again lol at the tags. I love em!
        That picture braces scared me. LOL
          Power Steering Cooler Install
          My dad installed the cooler for me today. It went together no problem, the hard part was removing the rusty old lines form the steering box. Just had to twist the lines apart and wreck everything to get the steering lines out. But aside from that the cooler that wagonman sent me fit right into place. The paint held nice even on the nut parts where the wrenches turn, so all is well. Oh and NO leaks!
          The lines at the steering box. The clip couldnt fit because of the aftermarket high pressure hose. The two lines weren't lining up so the clip would never seat properly. They are not going anywhere though.
          The connections just inside the radiator core support.
          And the cooler mounted in place
          And a peak through the grille. I will have to give that grille a cheapie spray job one of these days.
          Next up is exhaust!...I hope.
            Air Box Bolts Painted
            Painted the air box bolts today. Scuffed them up, primed, painted and cleared. Probably install them once I install the transmission cooler...then I can also install the fender supports. Tons of stuff to install....it never ends.
            The products
            Primed
            Painted
            And cleared
            And a shot of the braces waiting
              Paint Day
              Tomorrow is the day I have been waiting for since I owned this car...it will finally be painted. I am skipping school (I suck for doing so) and will be removing all trim tomorrow in the am and then driving to the body shop at 10:00 where the car will receive a once over by the paint shop..then it will be masked off and hopefully be wearing a shiny new coat of BMW Hot Chocolate Metallic paint. I am very excited and scared at the same time. Over two years of work went into this...and am just dying for it to be over. Car will be back with me Friday at some time. Wish me and the Blob luck.
                good luck pal. is it getting the pinstripes?
                  That'll be like the 4th time that passenger door has been painted within 3 years. :p About time though. I shouldn't talk, but I am. Can't wait to see pics of the beautiful finished product. Good luck mang!!
                    No pinstripes. Complete stealth look.
                      You know you gotta take a "before" picture when you're leaving for the paint shop.
                        I will take a before picture. And an after picture weeks later once the clear is fully dried, cut and buffed and the car totally assembled. Muahahaaahahahha
                          i can't recall...did you get new vinyl?
                            You betchya. Everything new on this car.
                            Spoke with the paint guy. Going to take him over 4 hours to just prep the car for paint
                              yeah I remember you peeling the old stuff off but didn't recall if it was in prep for a new top or just slicktopping it
                                Vinyl tops are sexy. I wanted to keep it looking like it was when I got the car.
