Originally posted by 86VickyLX
View Post
- Oct 2009
- 2878
- Keene NH
- Send PM
Thats going to look good, I just don't have the heart, or patience to drill into my speedo."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
Originally posted by 87gtVIC View PostNo. But I will have the added illumination anyway see post: http://www.grandmarq.net/vb/showpost...&postcount=467
Couldn't you use those smaller gauges so there'd be more room?2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Originally posted by 87gtVIC View PostI do not think there is a way to avoid them. So little room to work in that moving any which way lands you upon another problem. Another major difficulty is the fact that the speedometer slops downward as it spans from right to left giving one less and less room to play with on the left side.
Originally posted by pantera77 View PostCouldn't you use those smaller gauges so there'd be more room?
Originally posted by Nathan in MI View PostI thought it looked like that was the case. Does Blaze's thread mention the problem at all?~David~
Directionals Repaired
Some pics of the reconstruction
Now it is time to start purchasing some gauges.~David~
gauge wise? Just some sunpro style line white faced electric oil pressure and tem gauges.~David~
Originally posted by 86VickyLX View PostYeah. And what of the other oil psi and temp gauges?~David~
Right now I have underneath the ashtray a Voltmeter, a mechanical water temperature gauge, and a mechanical oil pressure gauge. In the police pod I have an air fuel ratio (light show) gauge, an amp gauge and a vacuum gauge.
I will be removing the amp gauge totally from the car and putting in it's place my voltmeter. I will be putting new electrical oil pressure and water temp. gauges into my speedometer and installing a replacement ash tray I have so everything is seamless again.
I was originally thinking of moving the voltmeter gauge to my single a pillar gauge pod but decided that I don't like the amp gauge so the volt gauge will take it's place.~David~
I've got gauge envy!!!sigpic
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Want me to make your gauge envy even worse? Dave actually has an envy gauge in his car, that registers the degree of envy shown by others when they see his gauges.
