Set out this morning to install the stifflers driveshaft safety loop....but was met with disappointment. Due to the design of the panther transmission cross-member I cannot use the stifflers piece as it does not sit flush but is obstructed by the thick tubing of the cross-member.
Piece in question that does not fit:
The hoop that surrounds the driveshaft and acts as the safety just does not fit either due to piece not sitting flush against the tranny tailhousing mount. No biggie.....
I then went and installed my Bilstein #24-014953 Front Shocks and Bilstein #24-014960 Rear Shocks...B6 monotubes.
Out with the old gas-a-just shocks.... Front ( KG5458) Rear (KG5521)...They are still in fine shape...stored away for future builds.
