Because of COVID-19; I will be getting a GoPro6 or something like that to record the 1st start and anything else after break-in. This is at the request of my friends.
Originally posted by gadget73 View Postprobably something with the audio compression. Tends to make things have a slightly nasal sort of sound.
Originally posted by packman View PostBecause of COVID-19; I will be getting a GoPro6 or something like that to record the 1st start and anything else after break-in. This is at the request of my friends.~David~
The upped tire pressure seems to be doing the trick. I can roll out in first and just get wheel spin with no bounce. Still under review and further testing but seems to have helped.
Some pics after I had her out in the morning:
On my last drive I had encountered a bit of rain. Resisted the wipers as long as I could just because I am weird like that but then had to go for them and I got nothing. Turned out the connector just wiggle loose off the wiper motor...I have the one plug design motor on there and the plug does not secure so good. Happy it was nothing inside the steering column or under the dash. I never tested things after the 5speed swap last year so it could have been any number of things because I had it all disconnected for removing the steering column and installing the pedal assembly.~David~
Nice!
Phenomenal.
My Cars:
Sounds strong and looks shiny. Remind me of your cam if you don't mind...1990 Country Squire - under restoration
Originally posted by mitymerc View PostNice!
Originally posted by Kodachrome Wolf View PostPhenomenal.
Originally posted by Tiggie View PostSounds strong and looks shiny. Remind me of your cam if you don't mind...
Originally posted by Mainemantom View PostVery very nice.~David~
Originally posted by packman View PostThat chop gotta turn some heads when you fire that beast up~David~
Originally posted by DerekTheGreat View PostFIVE OH right on the side... I suspect David was no more than 24 at the time lol
Some from this morning.
