Originally posted by mitymerc
View Post
Oh Doh! I may have to take remedial reading.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Originally posted by jaywish View PostI am sure a magnetic axle finder is a real thing but my first thought was I would find them on the shelf next to the left hand smoke sifters.
What does a magnetic axle finder do?
Jay86 Lincoln Town Car (Galactica).
Now why didn't I think of that?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Hey, I know where you did that!
From a buddy that knows his shit...
"It might not be square.
Tires will affect it if they're trying to hook/spin/hook.
SHOCKS?!
Rear may be trying to "dribble" the tires."
"Cheap street radials?
Have to treat the car somewhat like a drag car. Plant the tires & keep weight on em"
Also
"If he over tightened the rear suspension Id expect it to just spin. Sounds like combo of tires (soft sidewall, cushy ride?) & lack of suspension control (shocks)"
"Tell him to add air to the tires & see if it changes. Maybe 5psi just to test it. If it improves any try a little more. But if they're like BFG radial ta with a max inflation of 35, don't drive it a lot with 45"
Thats good info. Thanks Jim. And you caught me.
I know Phil (brownmuscle) has already commented on the shocks about two years ago....They were newer even then. lol KYB gas a justs in the rear. Push down on rear bumper and car does not just rebound and stay put...it took a few up and downs to stop.
It could be them.
Tires are Yokohama Avid Envigor High Performance All Seasons 235/60/16. I will look into upping the tire pressure by 5psi and seeing how things go.
If pressure does not fix the dribble (as that is precisely what it feels like) I will look into finding out what my pinion angle should be...do it and then test..if still bad look for bilsteins for the car.
A video of some prior wheel hop to refresh memories:
I'd forgot what a good small block sounds like. Very nice.1990 Country Squire - under restoration
Thanks. I just cant understand how the audio gets a bit messed up when putting it into the editing program from the phones recording. Aside from that slight nuance I am quite pleased with how it sounds in person. What you hear is what I head but with some slight noise.~David~
probably something with the audio compression. Tends to make things have a slightly nasal sort of sound.86 Lincoln Town Car (Galactica).
