That became my plan when I get my CV running. I was going to park the car during the late Fall and throughout the Winter. I figured that once a month I would start the car up and let it idle for a bit; then let it sit until the next start-up interval. Since my Mom has the Explorer as her daily driver; the CV became the fair weather car; and for the time being, it won't be driving in the rain until I replace the wiper motor.
SO I finally acquired a hard to find part for the car. NOS Passengers side headlamp bezel.
Been looking for a couple years for reasonably priced ones and finally got it. Guy had at least two. One chrome face and painted buckets as well as one full chrome one. I picked up the drivers side chrome face and painted bucket one because he did not want to spilt the pair. Now I have one NOS set of full chrome headlamp bezels and one NOS set of chrome face painted bucket version with an extra NOS drivers side chrome face painted bucket version.....All to go along with my three sets of NOS 79' clear parking lamp lenses (full sets of four).
The passengers side headlamp bezel was the final piece I was waiting on before swapping out my front and rear bumpers for the NOS fully chrome smoothie types I picked up through the years. Front one is a NOS 79 piece!
Still waiting on doing the 5speed swap. Again, I have all the bits and bobs and parts and pieces. Just need to do it. Clutch, pressure plate, flywheel and bellhousing are actually in my room reminding me everyday to get it done. lol~David~
what do you mean "painted bucket" bezels?86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Postwhat do you mean "painted bucket" bezels?
OH also have a NOS 1979 to 1981 grille for the car. Been searching for a NOS 1982 one but no dice.~David~
Ah, I see. Never honestly paid that much attention to them. Either that or most of them have half-shot chrome by now that you can't tell from silver paint.86 Lincoln Town Car (Galactica).
hell of a run. stoked to hear about he 5spd progress, im in a similar point in my build
Originally posted by 87gtVIC View PostIf any body happens to want the remnants of the derale kit (I just used the oil cooler) let me know and we can work something out. I have no need for it.Charlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
Alesha - Black 1982 Mercury Marquis - 255ci 178K, full custom Kenwood and Infinity system, lowered, dual exhaust, LED all the things
Tangerine Dream - Orange 1988 F-150 Custom - 300 i6 82k, Ghetto sound system, 5spd, 2WD, #farmtruck
Originally posted by marquis_82_withneons View Posthell of a run. stoked to hear about he 5spd progress, im in a similar point in my build
id be interested. i have an og cooler and lines but couldnt get the adapter off the block at the junkyard.
Once I find them I will get back with you. If it takes some time feel free to kick me in the butt in case I forgot. Dont know when I will be back at work to check there.
once I do find it I will post some pictures up for you to see if it is what you want/need.
EDIT. Did you build a pedal assembly yet? Also this item is a MUST if using a cable set up...the thing around the firewall adjuster:
Purchased from Pier:
Make sure to get the version like I have.Last edited by 87gtVIC; 03-27-2020, 08:48 PM.~David~
I'm down to the pedal assembly, clutch cable, and clutch. All the other bits are fully ready. Just finished an overhaul of a 96 disc swap axle, so the t5 is about to come apart for a rebuild now.
Did you buy that pedal assembly pre-made?
EDIT: I see now that the video was using the newer vic pedals.Last edited by marquis_82_withneons; 03-27-2020, 09:28 PM.Charlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
I made that pedal assembly above in the photo I posted..more about it starts here:
I only purchased the heavy metal clutch cable firewall adjuster mount from him. TOTALLY worth it. I dont see how it can be done cleanly without it.
There are things I would have done differently if I were to do it again...just minor positioning of things..mainly clutch pivot tube placement.Last edited by 87gtVIC; 03-27-2020, 09:36 PM.~David~
my issue at the moment is sourcing the fox pedal assembly. the rest of the hard to find bits ive already got luckily. im gonna toy with pedal placement in mine as well. hoping to fit everything cleanly.Charlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
The one I fabricated above fits damn well.
The only thing I would have done differently is position the clutch pivot tube more inboard by at least a half an inch. I think there is room for it to move inboard even more than that. The more inboard the better.
Issue I had was firewall adjuster screwed all the way into car and clutch quadrant contacting the adjuster due to my positioning of the clutch pivot tube in the pedal assembly being close towards firewall.
I built this all comparing to a fox mustang one off of my car two or so years ago. For it to fit as good as it does I am not complaining.
Fix was cutting an inch of the adjuster off (maximum motorsports firewall adjuster has a TON of throw in it so an inch out of it was NBD) and playing with maximum motorsports clutch cable spacer..a little spacer that goes over cable end and essentially shortens up the physical inner cable.
I recommend a maximum motorsports clutch cable. The overall length is longer which allows you to route the cable out the firewall, under the oil filter between the oil pan and chassis and directly into the bell housing.
If i haven't said it already pick up a double hook quadrant. It was needed in my application.
My cruise deactivate switch as well as the neutral safety switch fits easily between the computer and the pedal assembly. You even have enough room to easily remove the connectors for it.Last edited by 87gtVIC; 03-28-2020, 07:33 PM.~David~
I just looked over your thread...and after seeing the placement of the clutch cylinder in the engine bay I totally understand how you accomplished everything.
In stock mustang form the clutch pedal pushes down and the clutch quadrant pulls away from the firewall.
In your modified form you flipped the quadrant mount upside down (or lowered it a bunch) so now it pushes against the firewall.
This push action sends hydraulic pressure to your slave cylinder that then pushes against the clutch fork to disengage the clutch.
Your slave cylinder is mounted behind the tranny to bell housing mounts using that black bracket and pushes against the clutch fork.
Way cool. Totally get it.
Pics from Toms thread for referencing:
