Would you look at that. Interesting.
Originally posted by 87gtVIC View PostHow can I examine if there is a blanket of fuzz on the evaporator? Where is it visible from?86 Lincoln Town Car (Galactica).
Evaporator is not really difficult to do. 2 bolts on the bottom of the case under the hood. 1 or 2 on the top and the whole assembly comes out. You should remove or peel back the inner fender liner. It would also be the ideal time to replace the blower motor resistor. I've done quite a few of the Evaporator cores on these cars. The later ones are slightly easier because they added a retaining bolt from the inside of the car. Other than that the process to remove the EVAP case is identical from 1979 to 2011. The 2011 case even lines up with every bolt hole on the firewall of a 80s model.
Originally posted by gadget73 View PostPull the fan out, you can see part of the evaporator through that opening. Only way to really get more access is to remove the thing unfortunately.
Originally posted by 86VickyLX View PostEvaporator is not really difficult to do. 2 bolts on the bottom of the case under the hood. 1 or 2 on the top and the whole assembly comes out. You should remove or peel back the inner fender liner. It would also be the ideal time to replace the blower motor resistor. I've done quite a few of the Evaporator cores on these cars. The later ones are slightly easier because they added a retaining bolt from the inside of the car. Other than that the process to remove the EVAP case is identical from 1979 to 2011. The 2011 case even lines up with every bolt hole on the firewall of a 80s model.
Thanks John.
I also picked up a condenser. Says it is for 134a. Cannot be all that bad. I didnt speak to John beforehand. Hope I dont regret it. lol~David~
Went down to Johns place this past Saturday to exchange some parts and to have him tune/look over my car a bit. While down in Jersey, John and I met up with Phil. Seen his LTD-S the wagon and his Maverick that will be getting painted shortly. Phil then came along for a ride in the Brown Blob while John was working his magic on the car. Some highlights from the visit below.
While with John I went for a ride in his Vicky. That car is FUN and wild. Thanks again for your time. Appreciate everything. I had a good day.~David~
"You're adequately fueled."
You're starting to sound more New York.
Sorry I couldn't catch up with you guys, was out at Carlisle. Two box Vics there, one 89 and one 86 four door. No box GMs, and I think there were 3 box Towncars, one of them a limo. You really should bring this sometime, its not exactly a show rich with Panther cars. Better than half of what was there total were Marauders, and I think that was like 20 ?
I think my injectors run more duty cycle. What size are you running?
and is it better now?Last edited by gadget73; 06-02-2019, 08:21 PM.86 Lincoln Town Car (Galactica).
24 pounders. Single hole ford pieces.
Nothing was actually wrong aside from what my afr gauge was reading. Turns out something with my afr gauge is on the fritz as it did not put forth similar readings to Johns inovate afr gauge. Main concern was to see if the car is okay. It is though the tune that was on it wasn’t optimal. It had wrong injector data and I think John tweaked with the maf curve as well as a bunch of other things I know nothing about.Last edited by 87gtVIC; 06-03-2019, 05:47 AM.~David~
Wow you guys were five minutes from my house when you went through the new tunnel on RT42. Next time you are getting together this way shoot me a PM ... maybe we can hook up for a quick beer (or three).2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
Originally posted by tjc78 View PostWow you guys were five minutes from my house when you went through the new tunnel on RT42. Next time you are getting together this way shoot me a PM ... maybe we can hook up for a quick beer (or three).
Took the old gal out this morning. Snapped a few pics on the nice day:
The 8-speed auto gave the Charger a slight advantage. The 6-speed auto in the wife’s Escape turns the 2.5L into a rocket in gears 1-3.1990 Country Squire - under restoration
I think the 370 HP and nearly 400lbs of torque also plays a part.2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
Originally posted by tjc78 View PostI think the 370 HP and nearly 400lbs of torque also plays a part.
