Pulled the Vic in the backyard today to address some issues, things I wanted to get done.
First on the list was hardwiring in the dash cam with its power supply versus me having to plug in the damn power adapter every time I drive the car. That went nice and smooth and it is nice not having to plug it in. Got annoying when I had that to plug in to the lighter and my GPS and my phone charger…Less is more.
Next up was investigating the sweating going on around the oil cooler. One of the fittings appeared to be leaking a bit and caused a sweaty oily mess on top of the cooler.
Factory box panther cooler mounts to the left of the hood latch when looking from the front of the vehicle. The left most fitting was the leaker. (pic was from 2015 when I had the front end apart...one does not need to remove front end to install oil cooler)
Dropped the cooler down from its brackets and removed the line and then the fitting. I was going to put some thread sealer on the 90 degree fitting that goes into the cooler to help stop the leak.
Did so then notice that the fitting that is part of the cooler itself is cracked.
Found the leak and proceeded to remove the entire system.
If I ever find a stock exact replacement I will reinstall the system..until then into storage it goes....
