Originally posted by 87gtVIC
View Post
Originally posted by rellik god View Postyou can also coat the whole back with fiber glass resin for extra moisture protection
Originally posted by 86VickyLX View PostThose look more proper than the ones you have on there.~David~
listening to that AOD do it's 1-2 slop is hilarious, but it shifts exactly like mine does.86 Lincoln Town Car (Galactica).
Cool vids. Sounds vicious.
Are you pumping the brakes up before you engage the LL?
Man that sounds good. That would be one car I could appreciate blowing by me on the expressway.
My Cars:
This reminds me... I need to post a new WOT shift vid of my car. The trans tune I did is working like a champ. The shifts are firm and quick, but not harsh.
Also... I love your car.
Mhhhm boy now that's a good sounding 302! Loud and proud. I'm really happy for you mang; the ARP head bolt fiasco and multiple rounds of troubleshooting earlier sounded like a major slice of PITA bread. She's back in action though. Between the warmed over motor and the upcoming 5 speed (which assuredly has less parasitic losses in gear vs an AOD), you're primed to have a rip-roaring good time.Last edited by Hearsesrock427; 03-25-2019, 10:35 AM.'89 Grand Marquis "Ebyt", '85 Grand Marquis "Eva", '94 Caprice "Kira"
'80 Mark VI "Allie", '94 Grand Marquis coming June, '79 LTD-S "Oksana"
Originally posted by gadget73 View Postlistening to that AOD do it's 1-2 slop is hilarious, but it shifts exactly like mine does.
Nope. Just hold to floor HARD then engaging switch and letting off brake pedal. The RPMs sky rocket so fast I am just letting the switch off within seconds of starting. Its not rolling at all though while LL is engaged.
Originally posted by Kodachrome Wolf View PostMan that sounds good. That would be one car I could appreciate blowing by me on the expressway.
Originally posted by sly View PostThis reminds me... I need to post a new WOT shift vid of my car. The trans tune I did is working like a champ. The shifts are firm and quick, but not harsh.
Originally posted by DerekTheGreat View PostThat is indeed a good looking car. You have an aero rear end in that, right? I see the rear wheels actually look flush with the body compared to my box.
Originally posted by Hearsesrock427 View PostMhhhm boy now that's a good sounding 302! Loud and proud. I'm really happy for you mang; the ARP head bolt fiasco and multiple rounds of troubleshooting earlier sounded like a major slice of PITA bread. She's back in action though. Between the warmed over motor and the upcoming 5 speed (which assuredly has less parasitic losses in gear vs an AOD), you're primed to have a rip-roaring good time.~David~
Originally posted by packman View PostI like how your CV sounds just like an 80's Fox Body on deceleration~David~
Trailer Light Power Module and Bracket
Today I swapped on my favorite wheels in preparation for summer:
I also installed my trailer harness and 4 flat mounting bracket.
Easy install. Everything I needed (aside from power) was located right behind the drivers side taillight. I then mounted the trailer harness module in the quarter panel well behind the carpets. I used a 10x24 nutsert for that. I used silicone around the nutsert before installing and antiseize on the threads of the bolt.
Power was stolen from my latest under hood fuse box. Fuse three is now for the trailer light module. 15amp fuse. I will only keep it energized when I need to. Otherwise the fuse is riding in the glove box.
I drilled a hole and chopped off the trailer plug and used a grommet to run the trailer harness out to the trailer hitch. I used two 8x32 nutserts with p clamps to secure the harness out of the way. Again I installed with silicone and screws were antiseized.
I drilled and tapped two 10x24 holes in the trailer hitch for mounting the 4-flat trailer harness bracket for a nice clean install.
I used a Tekonsha 119147 trailer light power module and a Tow-Ready 118149 4-Flat Universal Mounting Bracket. I have zero complaints.~David~
Do you keep the tires on the wheels or do a re-mount at home?sigpic
