Been doing endless research on getting this 5speed swap down...the boring part of it...wiring.
I'd like to wire in all of the special doodads if they fit underneath the dash. They all attach to the pedal assembly:
p.side has the cruise control deactivation switch
d.side has the clutch neutral safety switch which consist of two doodads. One (top port (black connector(not pictured))) allows the power to the tfi and the starter solenoid when the clutch pedal is fully engaged while the other (bottom port(gray connector(not pictured))) tells the computer that the transmission is essentially in neutral/not engaged when the clutch pedal is fully engaged.
Cruise thing is easy. Intercept the output of the stop lamp switch (mounted on brake pedal) and plum it in then out of the cruise control deactivation switch.
black plug (top port) is not too bad either. Just redirect the wires to from the auto tranny mounted neutral safety switch to this plug and Im good.
gray plug (bottom port) requires a bit more work. Looks like I will have to add a pin to my ecu connector (pin 30) and the other half of that is just off pin 46 which is the sig return pin.
all in all not hard. Again, no clue if any of this stuff will fit. Just things I would like to do if it is possible.
