    There is also the electrical aspect of the install. Gots to find me some powers that come on with the door switch as well as when one turns the headlamp switch all the way to the left(?).
    If they're like the 4 doors, the wiring is already present in the doors for the lights, all you have to do is add the connector that has the bulb socket.
      Now that would be a pleasant surprise.
        In my case the connectors were there but there wasn't any power going to the passenger side one IIRC. I tapped off the floor light.
          Yes; that is what I found when I got the armrests from the MGM. I found to my surprise that the wire and connector were taped to the inner door frame of the CV. I failed to get the connectors from the MGM, so for reasons that I can no longer remember, the bulbs or the sockets didn't work. I will get back to that one day.
            Yes now that you mention it, mine also didn't have power, and I couldn't find the connector to make it right, so I too tapped off of the floor light.
              Funny that they'd put the connector in the door but not add the connector which powers it. I traced the passenger side lead to another harness that was just taped up behind the kick panel, so at least I didn't have to snake a wire through the tube. Can't remember if it was the same deal on the driver's side though.
                Driver side was powered already. I do recall that.
                  Duck tail mod.
                    Better than the duck lips mod.
                      Agreed. Didn't think chicks were still doing that but then again, I'm usually wrong. Thought the Blob was stored indoors/garage?
                        I don't have Facepalm so I don't know what the yutes are doing these days.
                          The yutes are the futcha.
                            Nope. Carcover life.
                              Fakebook seems more appropriate name for that clusterfuck sometimes, altho Facepalm also fits it quite well
                              Da fuq??? If I'm understanding this correct I sure as hell hope you're wrong, given what current people of lower age than us are like...
                                Ah, I see. Shows covers work just as well.
                                Fakebook, lol that is indeed more like it. I have an account, although I never post and never check it.
                                Sent with my phonic while eating biscuits & mustard with French-fried taters mm-hmm.
