View Post
Its been together for years, doesn't leak. Also may have been Permatex #2. Honestly its been long enough that I don't remember, and since its not causing me grief I don't particularly care.86 Lincoln Town Car (Galactica).
Oh I get that, it really doesn't take much to make them not leak. I was just saying that the ease of removal is inversely propotional to the insanity of the person who installed it - you tend to do things logically and in a manner suitable for the application, I go for overkill every single time and that typically ends up biting me in the posterior down the roadThe ones who accomplish true greatness, are the foolish who keep pressing onward.
I honestly would have figured it would fetch up on the drill and then spin right out. If you're using a bolt extractor, you want the biggest one possible. Drill the hole as large as you can without blowing through the side of the bolt. The small extractors break, and are an absolute pain in the ass to remove once they do.86 Lincoln Town Car (Galactica).
May still be able to use an external EZ-Out socket on it, it will go into the recess for the locating dowel. But yes, as Gadget suggested go with the fattest extractor possible, really sucks to break one into the very thing you're trying to remove.The ones who accomplish true greatness, are the foolish who keep pressing onward.
Any trash down in the treads that the tap pulled out?86 Lincoln Town Car (Galactica).
I believe the stock ones with the step indicate torque to yeild bolts. Thems are the ones with the torque value then rotate X degrees type instructions. I presume the ARP bolts will have their own installation destructions if its something other than the stock settings.86 Lincoln Town Car (Galactica).
Factory TTY bolts do not use washers. They do however have flanged heads, that's how you tell them apart - if it's got a regular hex head you can reused it, if it's got a flanged head it's a one-time-use TTY bolt and should be tossed and replaced with new. Also obviously one should not mix and match TTY and non-TTY bolts on the same head. Doing one head with TTY and the other with reusables is OK, tho idk why one would wanna do that...The ones who accomplish true greatness, are the foolish who keep pressing onward.
Glad to see it going back together.
Originally posted by 87gtVIC View PostAdjusting the rockers comes next.The ones who accomplish true greatness, are the foolish who keep pressing onward.
