Don't you Start.
Gotta box o' parts waiting to get installed.
New everything...
Tachometer, vacuum gauge, voltmeter, oil pressure and water temp gauges. All autometer arctic white gauges. I have fancy high heat wire conduit for the vacuum lines run as well as LEDs for all of the gauges illumination.
New Police spec KYB gas ajust shocks for the front of the car.
Working on swapping on an angled IAC valve control thingy as well. Will have to paint it so it fits in with the engine theme. The angled bit looks cleaner then the electrical connector pointing straight out like it currently does. It came on a 65mm throttle body I have and is SUPER clean. Hoping it works once it gets installed. No idea if the part is any good...the car runs fine now. Should be easy to tell once it is on if things are unhappy.
Started the car last night and tuned the radio and amp to play nicer with the sub. Plan to run and install the provided bass control knob for the subs amp one of these days as well. Looking into making a bracket that bolts to the underside of the seat to house the bass control pot. I don't want anything mounted to the dash so I figure underneath the seat will work well and still be easily accessible. Odds are I will never adjust the damned thing. One wonders why even bother to install it....I am tired of looking at it in my room so I'll just get rid of it by actually making it useful in the car.~David~
What happened??-Phil
Do tell1990 Country Squire - under restoration
Looks good with the Light bar.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Originally posted by Brown_Muscle View PostWhat happened??Originally posted by Tiggie View PostDo tell
I have not looked into anything further. Just paid the tow bill (350 big ones...OUCH) put on the HPP wheels, washed her and covered her up. PISSED.
Originally posted by jaywish View PostLooks good with the Light bar.~David~
That is a fancy light.
I can see why you wanted to park her.
These major overhauls often have multiple fail points.
Hope one day I can make myself accept that.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
350? Where did it puke on a cruise to Montauk Point?
ouch.
Yeah no fun there.... at least you've got it narrowed down to three culprits so it's only a matter of time before you figure it out.'89 Grand Marquis "Ebyt", '85 Grand Marquis "Eva", '94 Caprice "Kira"
'80 Mark VI "Allie", '94 Grand Marquis coming June, '79 LTD-S "Oksana"
Originally posted by Hearsesrock427 View PostYeah no fun there.... at least you've got it narrowed down to three culprits so it's only a matter of time before you figure it out.The ones who accomplish true greatness, are the foolish who keep pressing onward.
yeah, massive sudden leaks do sound more like freeze plug or hose failure than gasket failures. Those rarely pop in a manner that gushes coolant so bad that you can't get where you're going by loosening the rad cap to keep the pressure from building. There is a freeze plug on the rear of the head, along with the ones on the side of the block. Unfortunately they're all basically a bastard to access, and its easier to yank the engine to change them vs trying to fight it in place.86 Lincoln Town Car (Galactica).
Yeah especially if fancy headers are involved, there's very little space to work in - maybe enough to cock the old plugs out and hammer new ones in, but certainly not enough to get in there with any sort of cleaning tool (like a wire-wheel), and being the engine has been run for a while it's a pretty safe bet the plug bores will need some cleaning. Besides if one plug let go the others of the same type are suspects as well (but leaky head plugs do not suggest bad block plugs or the other way around, as long as block and heads did NOT come from the same shop).The ones who accomplish true greatness, are the foolish who keep pressing onward.
