My gates has been on there for 4? years now...not too many miles, but still going strong.
-Phil
Did you use any sealant on the pump-to-plate gasket? If no she's gonna leak again. Wish there was a way to do away with that stupid plate altogether, I can't think of a single good reason why that thing was even needed when the timing cover could have just been cast slightly differently and all would have been well. Also ALL bolts should get same sealant on their threads, keeps any and all coolant from seeping in and corroding stuff to the breaking point upon removal attempt. I like grey RTV, once that thing sets you're usually good to go till the pump shaft seal wears and starts weeping.The ones who accomplish true greatness, are the foolish who keep pressing onward.
Originally posted by His Royal Ghostliness View PostDid you use any sealant on the pump-to-plate gasket? If no she's gonna leak again. Wish there was a way to do away with that stupid plate altogether, I can't think of a single good reason why that thing was even needed when the timing cover could have just been cast slightly differently and all would have been well. Also ALL bolts should get same sealant on their threads, keeps any and all coolant from seeping in and corroding stuff to the breaking point upon removal attempt. I like grey RTV, once that thing sets you're usually good to go till the pump shaft seal wears and starts weeping.
I will for sure use RTV this time around.
I have thread sealer too and will utilize it on the pump bolts.
I think this pump was leaking in multiple areas:
a bolts hole, between pump and plate as well as the weep hole. Shitty pump may not be all to blame.
Hoping this one will do me right.~David~
I was thinking that looked like some traces out of the weep hole. I went through several pumps before I got one that held together. Can't honestly recall who makes it, but its been on the car for like 6 years now. Its even been off and re-installed I think twice now without giving me any shit.86 Lincoln Town Car (Galactica).
The one on my beater is an AZ special... it's been at least 7 years since I put it on. There may be a leak from the lower intake gasket (leaning towards this one) or that top bolt over the water port, but it's so slight... meh.
Finally got around to doing something my father even wanted to get done when he owned and drove the car (2000ish to 2004).
Before:
After:
Spot it?
It’s a 12volt DC plug! Amazing right? Lol
Some China special straight from Hong Kong via Ebay.
Nice hard plastic case with factory looks drawn me to it.
Little closer look:
Came with mounting hardware and even right angle crimp connectors for easy install. I removed the Marine cover and replaced it with a plane jane one I had on hand. Where the pod mounts there was a prexisting hole for the wires to route into and over towards the passengers side of the car where power was snatched from the amps "T" and ground was attained from a grounding bolt behind some of the carpet.
Me gusta.~David~
Nice outlet. I prefer a centered position due to needing to air up trailer tires and load helpers.
Nice and clean. Whats the other big plastic box beside it in the picture?1991 Mercury Grand Marquis LE SOLD
1972 Ford F100 Custom - 5.9 - Stock
2011 Ford Fusion SE - 2.5 - Stock
2018 Toyota Highlander XLE
Originally posted by sly View PostNice outlet. I prefer a centered position due to needing to air up trailer tires and load helpers.
Originally posted by Salty Dog View PostNice and clean. Whats the other big plastic box beside it in the picture?
Originally posted by Grand Marquis GT View PostI think that's his powered subwoofer.
Yep.
Mine is actually tucked up on the rear deck and you can't see it at all unless you stick your head in the trunk. It's above the torsion bars by a few inches.
Originally posted by sly View PostMine is actually tucked up on the rear deck and you can't see it at all unless you stick your head in the trunk. It's above the torsion bars by a few inches.
Nut and bolted between the upper parcel shelf and the rear interior deck carpet?~David~
Got the pump installed today. Letting it dry overnight before adding coolant tomorrow afternoon so I hopefully don’t run into any issues.
Had a “doh” moment when I rubbed in the silicone for the pump to timing cover gasket and let it sit to long before installing. Luckily I had another felpro gasket I was able to use. I got side tracked and cleaning the pump bolts took too long and caused the silicone to cure. Doesn’t help I left it in direct sunlight. Like I said DOH.
Looks like I forgot to install the air compressors coil wire.......~David~
Originally posted by 87gtVIC View PostNut and bolted between the upper parcel shelf and the rear interior deck carpet?
