It is an aftermarket fox body ford racing dipstick on a stock fox body carbureted dipstick tube. It was never a tight fit. That dipstick fit snuggly in the provided Mustang dipstick tube but the bends were all wrong so I did not use it. I think hotdog down hallway situation as well.
I cut and heated a piece of heat shrink around the sealing surface to try and "beef" up the tubes OD so the dipstick would fit snuggly.
I went for a leisurely 180 mile drive this morning and no dipstick blew out. Now the next test will be under WOT. Hopefully it still stays put. I said leisurely so there were no WOT runs on this jaunt.
Interesting info on the vent tube supplying air that the PCV removed.
I did some reading on supercharged and turbo applications were they say that this vent tube between the valve cover and throttle body MUST be removed because of the amount of positive pressure in the throttle body. It would just cause more crankcase pressure with it in place and under boost.
