Trick Flow stage 1
Y no EGR? No likey the look of it on there?The ones who accomplish true greatness, are the foolish who keep pressing onward.
Originally posted by His Royal Ghostliness View PostY no EGR? No likey the look of it on there?~David~
Vroom vroom y'all.
Originally posted by Grand Marquis GT View PostI take it you haven't driven it yet?~David~
Originally posted by 86VickyLX View PostSurging idle tune 4. Very nice.~David~
Originally posted by 87gtVIC View PostAt first I switched to that tune and the idle was SMOOTH, smoothest the car has been yet and I was HAPPY. Then I blipped the throttle and it did not know what to do anymore. It also made the engine shake and sound funny when revving it. I promptly switched back to tune 3 and it is happy and super responsive at all RPMS and as soon as you let off the gas the idle drops right back down to where it should be NO hunting at all.
Nope. Just doing it on the fly while running. Would this mean unhooking the cars battery?
Originally posted by 86VickyLX View PostWhen you're changing the tunes, are you clearing the KAMRFs? You should be otherwise it won't follow the tune exactly until it relearns.~David~
No. In the search bar of binary editor. Which you can do by pressing 'Control F' Type in 'Z_KAMCLR' This is the PID for clearing the KAMRF. Select it. And then change the value from Normal to Clear KAMRF. Write it to the ecu and then switch it back to normal and write it again.
Do this while running or with key on engine off?~David~
Where's the burnouts?
This is good, now our engines have the same idle.__________________________________________________
Originally posted by SVT98tIt has air ride. I've disabled it since I've been jacking it up and down.
Haven't driven it yet. First 500 on it will be easy. After that all bets are off.
Ordered an oil catch can to go in line with the pcv valves vacuum line. I have an explorer lower intake with only the itty bitty oil shield so I figured I rather try this out then outright replace the intake.~David~
