If its tight it'll do OK with 5w30, if the oil pressure sucks run 10w30. Mine isn't super tight and it does fine with 5w30. I think I'm around 20 psi hot idle in gear, and thats fine. It will hit the pressure regulator at much above idle.
are you going to bring it to the guy to be fine tuned? 10-12 is rich as shit, 12 is acceptable WOT, 10 is too rich no matter what you're doing. he could have this tuned fully very quickly in person-Phil
What weight does builder specify?
Big steam__________________________________________________
Originally posted by SVT98tIt has air ride. I've disabled it since I've been jacking it up and down.
Steam oil is thick shit. I doubt thats the right grade.86 Lincoln Town Car (Galactica).
Originally posted by Brown_Muscle View Postare you going to bring it to the guy to be fine tuned? 10-12 is rich as shit, 12 is acceptable WOT, 10 is too rich no matter what you're doing. he could have this tuned fully very quickly in person
Originally posted by mitymerc View PostWhat weight does builder specify?
Originally posted by Bobcat View PostBig steam
Originally posted by Bobcat View PostBig steam~David~
Originally posted by 87gtVIC View PostChooo-chooo
Originally posted by gadget73 View PostSteam oil is thick shit. I doubt thats the right grade.
I run 10w30 and wouldn't go any thinner, since roller rockers make some good noise when hot.__________________________________________________
Originally posted by sly View PostThere's a Mighty Car Mods joke here...
Originally posted by Bobcat View PostTouche. Looks like he needs raw crude oil.
I run 10w30 and wouldn't go any thinner, since roller rockers make some good noise when hot.~David~
John and Phil
Here is a datalog from my car:
Looks like the TPS readings are inaccurate as I have the thing set EXACTLY at .98 at idle.Last edited by 87gtVIC; 05-04-2016, 02:42 PM.~David~
by my power probe.
BE sees that as 1.27~David~
