    Awwhhhh fucka-U
    BIG thanks to John (86VickyLx) for steering me there. My tuner was thinking the same thing.
    Should get it milled but right now thicker compressible gaskets I had on hand are doing the trick.
    IT RUNS and idles between 600 and 1000 all on its own!
    It RUNS shity. lol
    Still work to be done but good none the less.
    NO CODES and passes two consecutive cylinder balance tests (doing two in a row tightens up the parameters it is testing).
    To be continued.
      Glad you found the issue!
      -Phil
        It runs it runs!!! This thread is turning around! Hope that's the only problem!
          Yay!!
            Well, that would explain it. Big ass vacuum leak indeed. Surprised a stock casting is that whacked out. I wonder if those tubular intakes just aren't as stable as the chunkier cast Explorer piece.
            Also, how flat is your straight edge? I do see China on it, and its a carpenters tool. I think I've got that same one at work, and we actually filed it flat using the table on the drill press as a reference surface. A steel rule out of a combo square is usually a pretty decent straight edge.
              Must be a huge relief to have found the issue. Good luck with the tune and finishing it up!!
              Past Panthers
                dayum... that's a HUGE f'n gap.
                  That's gotta be a great eureka moment, not to mention a huge relief. Like Tiggie said I'm glad this is turning around, staying tuned for further updates..
                    Sweetness.
                    Originally posted by SVT98t
                      Video?
                        That's awesome. Where's the friggin celebration vid???? :-p
                          Straighter then my intake! We used a couple different things to check the straightness of the intake. It was wonky. No clue how it could have gotten that way especially considering the lower intake is perfectly flat. I purchased the pair together from the same seller.
                          It was nice to not hear that noise again. Thanks.
                          Yeah. It would look even bigger if I had taken a picture with a level that spanned both ends.
                          Going away again for a couple days...progress after that? Did pick up a 5 gallon gas can and dumped 93 in the tank. She was running LOW.
                          Originally posted by Bobcat View Post
                          Sweetness.
                          BIG STEAM!
                          Video?
                          I was concerned the engine was camera shy.
                          Again. Celebrations will be had by balding tires and smoke.
                            What's odd is that Bobcat's engine had an intake that looked like it got hit by a triaxle or something, slight bend to it where the runners leave the EGR spacer flange area, but it sealed up just fine? Yours is nice and straight, and does not seal! WTF? lol
                              The way she goes sometimes.
                                True that, it is what it is! Btw you got a PM
