View Post
Passenger side in the kick panel area. You can find it easy enough, but access is not real fun. Just imagine laying under there trying to re-pin the thing from under the dashboard. Apparently if you do it just right, you can extract the connector back into the engine compartment, but rumour has it that the hole that it passes through is precisely the right size and if you don't have it angled just so it will not come back out of there.
