Thanks Tom. The weather today was freakin gorgeous!
Continued working on the disassembly this afternoon. Removed a ground from the back of the passengers side head (o2’s also grounded there) as well as a ground near the front of the passengers side block. Removed the thermactor tube thing that goes between all of the smog stuff and then enters the h pipe. Finished up under the car by removing the two engine mount bolts.
After that we started removing a lot of the top end as well as accessory pieces, radiator drained etc etc...
Some pics I took for my own reference whenever reassembly time comes around....Also disassembley pics.
Those guys that have removed the smog pump but still have AC...did you use a piece of pipe or something to take up the room for the smog pump for the lowest bolt hole for the compressor bracket?
