Where did you get the fan blades w/centers again? Can't find the post. Thinking of replacing the wheels on the vic with 16" w/tires. It will need new tires soon.
Originally posted by sly View PostWhere did you get the fan blades w/centers again? Can't find the post. Thinking of replacing the wheels on the vic with 16" w/tires. It will need new tires soon.
I actually do not see a listing for a set of wheels atm. They are 17" btw.
Originally posted by rellik god View Postwhat year,car is that Driveshaft from~David~
found it: http://www.ebay.com/itm/17-Replaceme...item3cbea765a4
hmm... 17s on my aero vic. Need some photochop for giggles
Looks good Dave. John said he noticed a difference on acceleration with the Al driveshaft. Do you feel any difference?-Phil
Originally posted by sly View Postfound it: http://www.ebay.com/itm/17-Replaceme...item3cbea765a4
Originally posted by Brown_Muscle View PostLooks good Dave. John said he noticed a difference on acceleration with the Al driveshaft. Do you feel any difference?
Cannot say. I am sure it did something with how the car boogies How much of something.... I have not a clue.~David~
usually the gain is it stops vibrating at speed. I'd like to find an AL one, but at the moment I'm happy with one thats not dinked. My original is heavier duty, but the yoke is damaged and its out of balance. The car shook like an overloaded washing machine over 70.86 Lincoln Town Car (Galactica).
Today I installed my TFI relocation Kit as well as a belly pan from a newer Grand Marq.
I pulled the TFI heatsink from a Thunderbird and modified the ridges so the TFI prongs would fit. I purchased a TFI extension harness for the three pins that the TFI module has from Mccully racing motors and the stock TFI plug with harness if actually long enough to reach where i mounted the heatsink.
Heatsink mounted with TFI module in place:
Everything all buttoned up a cozy looking:
I made a block off plate so debris does not get into the distributor, in this pic you can also see the Mccully racing motors TFI harness:
Also threw on a bely pan:
I had to make all new mounting locations for it as none of the factory holes lined up to anything.
4 J clips in the radiator core support
1 large plastic push pin on each side of the core support
3 bolts holding the rear of the belly pan to the K member below the oil pan.
I did need to trim a bit around the passengers side sway bar bushing, but otherwise fit is pretty good.~David~
Nice work,03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Great clean work as always. What's the benefit of the relocation? Less heat buildup?2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
nice as always Dave.
Originally posted by tjc78 View PostGreat clean work as always. What's the benefit of the relocation? Less heat buildup?
For the mounting of the heatsink I utilized the existing hole from the washer/coolant reservoirs. Did need to shave down the mounting ear as it was too thick for the original bolt to fit though, and did need to drill and tap a lower hole to ensure that the heatsink wasn't going anywhere. I also grounded the Mccully racing motors harness on that lower bolt hole.~David~
Looks good! What year marq did the belly pan come from? Looks like a great aero mod, I assume by the pictures you have to take it down to change the oil filter/drain the front plug?-Phil
