check the powered subs on crutchfield for an idea... there's a TON of different options. If/when you find one you like, then search for best price and so forth.
Thanks for the tips Jason. I will look into it further.~David~
Yay did some work today!
Lets start with the nightshaded and clearcoated ditch lights and quarterpanel extension parking lights....
Next up the 1979 ONLY license plate housing that I refurbished...
And finally a low fuel LED added into the cluster....
off
On
Looking good!2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
Thanks...
And oh boy...I just ordered another round of goodies...
distributor o ring, ring and pinion install kit, oil pan gasket, oil pan and a stainless steel intake bolt kit....next round will be rear gears and the 1.7 roller rockers.
I recently picked up the poly energy suspension rear control arm bushing kit and a 1/2" GT 40 intake spacer as well. Tons of work waiting to be done to this car.....Last edited by 87gtVIC; 03-30-2013, 05:10 PM.~David~
The night shades came out nice. I havent attempted to do any tinting of my lights cause, im scared I will fuck them up. lol
Thanks Julian. It was easy to do. Wet scuff with a dull gray scotch brite pad, duplicolor adhesion promoter, nite shades then clear coat. Let dry a week then some compound to get the dry overspray off and make it shine!~David~
Dave's my boy - always does something different but always turns out well!! Love his attention to detail. Bobby
Oh and I forgot to mention....just like everything else in my speedometer this led is soldered into the printed circuit still making my cluster plug and play!~David~
Don't know if it was hand made bit I hand stitched it onto the wheel! Check out the link of the install. It is a wheel skinzs cover.
Originally posted by BuffaloRider View PostThe brown blob is simply magnificent. Those ditch lights are looking fresh. The low fuel LED... I must have one. Is that steering wheel cover hand made?~David~
really like the tinted lens look. i plan on tinting mine once they come for my black Merc. tinting just looks so manacing on dark colored cars and yours is no different. love the speedo mods too! im curious how you wired up that low fuel light.Charlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
Alesha - Black 1982 Mercury Marquis - 255ci 178K, full custom Kenwood and Infinity system, lowered, dual exhaust, LED all the things
Tangerine Dream - Orange 1988 F-150 Custom - 300 i6 82k, Ghetto sound system, 5spd, 2WD, #farmtruck
Thanks guys.
The low fuel light...one side to ground, the other to pin 6. Pin six is a yellow wire with a black stripe and gives the power to the led once fuel reaches a certain level.~David~
Thanks Gabe
Here is the updated to do list... Parts in red still need to be purchased. Rest are all in my possession....
- Chevy. GMC Truck Sport Lower Valence (Has fog lamp holes)
- Sexy mini Marchal fog lamps from Rangers/Escort GT's
- Addco 509 1 1/4 Front sway bar with enlinks etc.
- Stock Box Panther Police Oil cooler
- Big brake upgrade/ Complete with Energy Suspension Poly Bushings I had installed over at Scotts
- Engine mounts
- Ford Racing 3.73's Complete with ford racing install kit
- Trac Lock Clutch Rebuild kit
- Ford racing rear dif cover
- Tubular GT 40 upper intake with matching lower
- Fuel Injector Rebuild Kit
- Lightning EGR Spacer with matching lightning 65mm throttle body
- Motorcraft thermostat
- Motorcraft PCV valve with new pcv screen and grommet
- Cast Aluminum Mustang Valve cover (a different set to be painted with VHT wrinkle paint)
- Crane 1.7 Roller Rockers
- Ford racing 1/2" intake spacer
- HPP wheels!
- Oil pan and gasket
- Distributor O Ring
- Stainless Steel Lower intake bolt kit
- Rear Control Arm Energy Suspension Poly Bushings
- HAVE TO FIND DRIVERS SIDE FENDER..Mines rusting like a banshee!
I think that is this bulk of everything.........~David~
