    dave can you please post up pics of the air injection pipe hooked up to the cats. where i live i need that hooked up so i really would like to see how you hooked yours up.
      actually i am interested as well...i was gonna fab one out of high temp silicone hosing...however if the mustang one fits perhaps i could use that (Even though our air pump systems are different)
      -Phil
        I put the one pipe into the other down by the H pipe (I used some High temp cloth pipe wrap with a mini u clamp to secure the two piece firmly). that pipe travels up top and get secured to the manifold bolts and has a solenoid (or some sorta bell shaped valve thing) that is plumed into the smog system to push air into the cats..just like any stock car.
          that secondary air tube is not nessassary. i belive it was mostly intended for cali emissions standards. you can plug the system right at the T off by the inner fender. if you insist on having it, you can buy high heat urithane hose to make your connection between the cat and metal plumbing. iv done this on my brothers town car a few years back and its still in tact.
            urethane you say? interesting! i wonder what the difference is between the silicon high heat hoses, and the urethane ones. I intend to keep mine intact.
            -Phil
              the stuff i got is different layers(2 layers) of urithane, rubber, silicone...what ever it is lol
                ah! makes sense, the stuff i have used before was two layers, must be the same thing.
                -Phil
                  if possible can we see pics of this hooked up. getting my exhaust done next month and need pics to help me.
                    matt check this thread out. http://www.grandmarq.net/vb/showthre...injection-pipe
                      Still haven't done anything with the body bushings or front end bushings..But I did order more stuff from Summit.
                      Ford Racing Spark Plug wires, A nice ball milled aluminum wire separator, MSD Cap and rotor kit as well as an MSD blaster coil.
                        please post up pictures when you install them! especially the aluminum wire separator!
                        -Phil
                          Will do. I will be painting the piece first though to match my engine bay scheme.
                            I've been considering upgrading to MSD stuff. But haven't really had any need to yet though. They sure do make a good looking product too. Looking forward to see how they look in your sparkling clean engine bay.
                              Me too Scott. Unfortunately the MSD cap and rotor kit arrived broken. One of the terminals was cracked clear off of the cap.
                              Washed and waxed the car today since the weather was not bad out. Also a quick pic of the amp pull switch. Still have to remove the chrome rocker next to it as well as the triple rocker panel underneath the headlight knob to make everything complete.
                              Also gotta snag some nice snake skin aka nylon meshy tubing from work to make the back of the indicator light as well as its accompanying wiring disappear behind the amp pull switch.
                                did you know, you car is fuck'in sexy? looking good mang!
