Just for my own curiosity ..why did you mask the center section of the drums ?
Originally posted by 87gtVIC View Post...to hopefully be installed this weekend.
1991 Mercury Grand Marquis LS - Current - June 2016 POTM Winner
1996 Mercury Grand Marquis LS - SOLD
1991 Mercury Grand Marquis LS - SOLD
1987 Mercury Grand Marquis LS 2dr - Long gone
Originally posted by hypostang View PostJust for my own curiosity ..why did you mask the center section of the drums ?~David~
You can also sandblast the exterior of a drum to make very quick work of the rust.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
Most definitely.
Today I finished up the egr valve...and prepped the alternator bracket for paint. Will be removing the compressor bracket and support bracket in addition to coil bracket soon. Then..eventually the cruise solenoid vacuum thing will be removed and sprayed in addition to the blower motor housing. Then the engine will be thoroughly cleaned...hope to pick up some nice cone shaped brushes if I can find some to get down deep and in between stuff.~David~
Everything is done in Rustoleum engine primer and paint. Aluminum for the mounting base and low gloss black for the bell.
Okay I will let you know. All will be fine though. Have the rest of the intake painted with this stuff for many months now and all is good. You can just click on my sig pic..scroll down to paint and read what is painted.~David~
Thanks Gabe.
Today I removed the radiator shroud (should have done that first lol) as well as the fan. painted the blades of the fan aluminum...the center will be painted black in a couple of days. I dont think the clutch should be painted so I may leave that alone. I removed and painted the compressor bracket, and painted the alternator bracket that I had bathing in evaporust. I removed the compressor support bracket, coil bracket as well as the coil. All hardware and everythign will be painted including the coolant reservoir bolt (90 TC style) and radiator shroud bolts...everything.~David~
Originally posted by P72Ford View PostYou can also sandblast the exterior of a drum to make very quick work of the rust.
Thank you, Nathan. That works spectacularly, but not everyone has convenient use of a blast cabinet. I did for a year or so, and it was amazingly awesome.
I do keep hoping to save up for a cabinet .... that, plus the big compressor to actually keep blasting for more than 15-20 seconds at a time. Maybe if I quit finding a need for parts ....Last edited by 1987cp; 05-10-2011, 07:41 AM.2012 Mazda5 Touring | Finally working on the LTD again!
Harbor freight has a cabinet I continue to eye every time I visit.
Today I painted all of the hardware for the fan shroud, coolant reservoir, compressor bracket, compressor support bracket, coil and coil bracket...and painted all the items the hardware belongs to. I have no finger prints left because of all the sanding.Everything is coming out very nice and it should look pretty nice once the car is put back together.
I also installed the freshly painted drums and it really does make the rear end look a hell of a lot nicer between those big spokes of wheels I have.
Tomorrow I want to finish painting the fan, clean the clutch for the fan and clean all the gunk left on the engine..mainly compressor, smog pump and anything else I can access while all these items are off the car.Last edited by 87gtVIC; 05-10-2011, 07:04 PM.~David~
Finished painting up the fan, painted the neck and mounting point of the clutch, painted the cruise control vacuum solenoid thingy, half of the IAC and half of the cruise solenoid bracket (two toned)...and of course all of the hardware for those pieces.~David~
