1986 Crown Vic LTD on 20's!!!
Look at the tread pattern.
I like the way it looks too. Interesting color.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
Shoot, I didn't even I realize that, I had somebody else get it done for me because I had to work, that won't be a problem though will it.
Also, thats the factory paint, and I took the top off on the back there, so that part has primer. I plan on getting it painted a darker blue, like portdizzal's wagon.1986 Ford Crown Victoria Ltd
It will be a problem, for the record- the tread pattern is designed to push water outward, but being backwards it will direct rain water toward the center of your tire and you could lose some steering ability in the rain. Get it fixed ASAP. As Johnny said, it shouldn't be a big hassle.
...and I'm with the others. That bitch is SHARP on those wheels!!2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
Actually check the drivers side rear and see if the direction is correct on that one... Might just need those swapped... There should be a arrow on the sidewall that shows the direction the tire should be rotating if the car is going forward.Builder/Owner of Badass Panther Wagons
Originally posted by LTDMan83 View PostNice Box! Ever get that B-pillar rust fixed?
'18in is as large as I would go personally. It starts to look a little Donk-ish after that IMO.
I wanted to go with 18 but these rims were too cheap to pass up.1986 Ford Crown Victoria Ltd
20's look fine on panthers. some 22's look good too depending on style.
you cant go wrong with wire wheels. a friend of mine had a 94 grand marq on 20" wires like that, looked really good. then he went to a 22" with spinners. didnt look as good, but did not look like shithttp://secondhandracing.com/Home.aspx
I think I can clear 24's on mine. Im not trying though. But the thought has crossed my mind. I love big spokes on box. Looks awesome.1989 Grand Marquis LS
and your car needs a set of clear cornershttp://secondhandracing.com/Home.aspx
Oh I forgot to mention, I haven't noticed any difference in braking or anything with these bigger rims, drives the same as before I put them on (just in case anyone was wondering.) That was one of the major reasons I waited so long to put them on, I was contemplating whether to spend the money to do the brake upgrade or just "wing it".1986 Ford Crown Victoria Ltd
