I paid $650 for the car and have been doing little repairs and replacements on it since i got it back in the first week of may. Its my first car and i think im gonna like it. I got a new oil pan and need to have it installed. A nice MSD Blaster TFI ignition coil, i replaced the air pump for A/C and got a belt, and found out now i have a window stuck open. But its not on the road yet so i dont have to worry about my pioneer cd player i got with the car being ripped out.
My 87 Grand Marquis LS
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Looking good! We'd love to see more pictures if you've got some.
Did someone say oil pan??-2004 Crown Victoria Police Interceptor - Daily Driver - 17" Bullitt's, 235/55/17 Goodyear Eagles, Ex-NH State Police, best 1/4 mile time; 15.3 @ 90 mph
-1987 Crown Victoria 2-Door - Project - 90k miles, Summit chambered muffler, Sunpro gauges, parked since 2010, fate tbd
oil pan aint bad if you have a hydraulic engine hoist. just need to remove the upper intake, connect chain to engine, remove the horizontal motor mount bolts, and lift. gonna have to get the bottom end of engine turned the right way so that the pan can clear the crank and such, but can be pulled out. removal of radiator, shroud and fan make it easier to have room to lift the pan up and out of front of engine.
while you have the water pump off, i would replace the timing chain, and gears
with pan off i would replace oil pump, and rod bearings and use a perma-dry felpro blue rubber gasket for oil pan.
Sunday i hopefully can get the new water pump on. i had ordered the 2nd gasket from auto zone on the 29th and it wasnt in to pick up till today. and sunday my friend is suppose to help put the pump in. well im at it i should buy the new radiator.2018 F150 XLT 43k
1970 Buick GS 455 Stage 1 44k
1968 Buick Riviera
Pimp.
. . .. sorry it's just my word this week.
And pretty darn clean, I like!Ont And Canada PPL The Cookhouse in Dwight
91 Grand Marq . . . . . . 88 ho wagon (project) . . . . . . 80' Lincoln Mark VI
you should replace the timing chain now that you got it all apart that far already. the only original thing left on my engine is the ac compressor. I've replaced everything else
