Got some stuff in! All my avenues for Cobra valve covers have come to be a bust, However!! I did get to see the underside of my valve coves compared to the cobra, no difference. Even the baffles are the same, so my HO valve covers will clear these 1.7 RRs!!!! Anyways on with the pics.....yes I am such a loser that I set them up like that for picture taking LOL
Yeah, so the above used injectors turned out to be crap after I installed them. Half of them did not initialy work. I got most of them to work after some tapping on them. But I was not happy, so I sent them back and got some brand new Ford Racing "high flow" 19# injectors. Note that Ford Racing "High Flow" injectors are OEM injectors (identical to the factory ones on my 95 HO), despite their warning that a callibrated MAF and tuned ECU are needed.
While I had my intake off I moved my air temp sesor and modified the PCV hosing. I had to replace a freeze plug at the end because that is where my air temp sensor used to be. So I took pics of something most will never see!
So first I replaced my old injectors with the crappier used ones. I don't have pics of the new Ford Racing ones installed, because I did that after work and was pressed for time.
While I had my valve covers off I simply did a wash and wax job on them. They cleaned up very nice IMO.
Here are a few close-ups of the Ford Motorsports Crane Cams 1.7ratio alluminum roller rockers, and the Comp Cams valve springs. Before I start installing them all.
Here are some pics of them as they got installed on the engine.
And some pics of the valve covers back on....all shined up!
All and all it was a pretty easy install of all the parts. Was especialy surpised at how easy installing rockers on this engine is. Bolt and go!
