The new Thunderbird.
    Video no worky. Is the retardedness at my end?
      ^^Not this time.
        Bullshit at work, sorry.
          Not too shabby, Pie rat.
            I was busy checking out the awesome calves of the guy in shorts.
              I was just going to mention the large chiseled calves, but you beat me to it.
                Who's the ugly fat dude?
                  I drove it today. It actually runs pretty good after the wee bit of work that I've done under the hood. Runs a lot smoother than I can recall, but I need to put a driver's seat back in the car so I can get a better idea as to how it drives.....and I'll more than likely take it for a longer spin this evening.
                  I have a super sneaky plan that involves me putting a set of new tires on it, and driving it on sunny days during the winter, just for giggles.
                    Some random pics....
                    New valve cover gaskets:
                    Another disassembled shot:
                    It's since been reassembled and runs....and whaddya know, no smoke now!
                    Here is why you should remember to clean your PCV filter in the back of the intake:
                    In this second shot, you can see that the filter is completely clogged:
                    And....here is the gauge cluster with Autometer blue 194 LED bulbs installed:
                    I don't know if I'm going to leave the blues in, as there are a couple of dark spots (you can see them in the picture)....I've also got ideas of ditching the stock gauges, and adding something aftermarket in their place...sometime down the road.
                    More later...eventually.
                    Last edited by Guest; 11-12-2010, 12:10 AM. Reason: That's nice, photobucket isn't working in here.
                      the pcv screen is exactly what mine looked like. did you mangle it trying to pull it out? i couldn't get the damn thing to come out of there.
                        Yep. That's what the frilly wire is in that one screen. I actually paid a guy to change it about a decade ago (leaking FPR, upper has to come off to get to it), during a busy spot when I didn't have time to work on it....and it looks like it was missed just a bit.
                        I used a pair of needle-nose vise grips to pull at it....and eventually, it popped out, but only after I pulled like hell.
                          I was worried that little bits of the screen would be snapping off and falling back down there mucking up my oil.
                            I just used a 3 inch long sheet rock screw to fetch the one out of my 88. it wasn't quite that bad, but it was well clogged.
                              It looks clogged from the start. What actually passes through it?
                                oil saturated air. It's below the PCV valve
                                Looks like that car hasn't been started in awhile. Very dry rocker arms.
