I replaced the ignition control module and inspected the connector harness; at least as far as I could until it went into the firewall. I didn't see anything obvious like severed or chewed wires. The ignition module is a replacement as its spade terminals look new; and the 2 bolts that fasten it to the steering column are Home Depot bolts.
I also looked at all of the wiring in the steering column and although kinda dirty; nothing is severed. I will wait until my replacement ignition cylinder comes in and install it. Then see if anything changed. Other than that, I have no clue what to do other than pulling the engine and checking the wiring coming out of the firewall.
