My Ma's 1986 Crown Victoria LX
I took advantage of the weather on Saturday and organized the passenger side fender a bit. I separated the ignition coil wiring from the harness as I will relocate the coil to the front of the engine. I put cable terminals on the auxillary fuse box cable and the starter solenoid cable; then I installed them on the bus bar. Cleaned up the fender nicely. When I get things a bit more finalized, I will cut the zip ties, move everything off of the fender, then I will clean and paint it. I will do the same for the driver side at some point.
Much better than all that factory smog junk on the passenger side.1990 Country Squire - under restoration
So much can change in a short period of time. After adjusting to new routines both at home and at work; I was able to get some time with the CV. I installed the fuel rails, water temp gauge sender, and re-grounded everything. I originally was going to run fuel into the front of the rails and have it exit out the back and go to the fuel pressure regulator. But that freakin wiper motor box is at it again; being in the way and all. So I had to route the exit on the bottom port of the driver side fuel rail; and grind a little material off of the wiper box so the fuel rail would bolt onto the intake manifold. I ran a stud into the driver cylinder head and then ran a ground strap down to the engine mount stud. I figured with the aluminum heads, I would get a better ground by doing that; keeping in mind that I know very little about electrical systems. I came across a new problem which halted progress for the time being. My coolant crossover tube-assembly will not work with the new set-up. So I am scrambling to figure out how to run the engine coolant temperature sensor. Hopefully I will figure that out before the next decent weekend comes around.
Originally posted by packman View PostSo much can change in a short period of time. After adjusting to new routines both at home and at work; I was able to get some time with the CV. I installed the fuel rails, water temp gauge sender, and re-grounded everything. I originally was going to run fuel into the front of the rails and have it exit out the back and go to the fuel pressure regulator. But that freakin wiper motor box is at it again; being in the way and all. So I had to route the exit on the bottom port of the driver side fuel rail; and grind a little material off of the wiper box so the fuel rail would bolt onto the intake manifold. I ran a stud into the driver cylinder head and then ran a ground strap down to the engine mount stud. I figured with the aluminum heads, I would get a better ground by doing that; keeping in mind that I know very little about electrical systems. I came across a new problem which halted progress for the time being. My coolant crossover tube-assembly will not work with the new set-up. So I am scrambling to figure out how to run the engine coolant temperature sensor. Hopefully I will figure that out before the next decent weekend comes around.~David~
It worked when I pulled it off of the lopo; but this engine is so much taller than the lopo, it crams my wiring and plumbing into a tighter space. If my computer doesn’t act wonky tomorrow, I will post pics. Too bad though, because I cleaned and painted that crossover quite nicely
Wiper motor is coming off for the time being. This particular engine combo makes it a lot taller in the engine bay. The throttle body juts into the wiper motor. It was suggested that I retrofit a wiper motor from either an '88 - '91 box or use a Whale wiper motor. I will worry about wiper motors after I get the car running.
Originally posted by packman View PostWiper motor is coming off for the time being. This particular engine combo makes it a lot taller in the engine bay. The throttle body juts into the wiper motor. It was suggested that I retrofit a wiper motor from either an '88 - '91 box or use a Whale wiper motor. I will worry about wiper motors after I get the car running.
