well what size are them bolts that hold the stockers down, 3/8 or 7/16"? You can get RRs for both, hope you got the right ones
Almost there Mangs!!!*DUW*
i dunno if tou can use stud mount rockers on pedestal mount heads or not.....turbo would know......might just be a matter of getting some studs and polylocks.
i think you need this kit mang
Originally posted by Mercracer View PostIt is a simple machine job to lower the pedestals a bit. Then you drill and tap for 3/8 or 7/16 studs and bolt your rockers down. There are a couple of kits with 5/16 adapter studs but they are made for very low lift cams only.
That's it... I'm no checking this thread until Saturday afternoon!
Everything I do takes longer than expected.1990 Country Squire - under restoration
Originally posted by MeLikeyStripperChicks View PostI thought them pedestals are drilled and tapped already - ain't it a bolt that holds down the stock rocker? Or you mean they need to be drilled and tapped further down the pedestal cause if not done studs won't have enough thread to hold to?Scars are tatoos of the fearless
Originally posted by Mr. Land Yacht View Postso, dave...what do I need to get to make those fit properly?
the link that Scott posted?Scars are tatoos of the fearless
Oh boy. You need to find out if Gerry machined them for screw in studs. If he did your rocker geometry woud be way off with pedistal mount rockers. my guess is he diddnt because the threaded holes in the head would be 7/16 and the bolt on rockers wouldnt fit because there 5/16 thread. Best to sell them off see how the car runs. Get it broken in ,tuned up worry about rockers later. I dont realy recomend those conversion kits. Later some bolt on roller rockers would be the ticket. Would probably stick with 1.6s.Scars are tatoos of the fearless
