Here she is with the new pony wheels and 245/50/r16 wheels. Handles MUCH better than before on those granny tires.
Pics of the engine tomorrow or something
I put them on with 1.25" spacers from ebay. The wheels fit fine and they don't rub or scrap anywhere.
