Thats enough. V4 for economy. piss off with that variable displacement nonsense.
The 93 GM "Tank of Justice II" (TOJ2)
All the pistons are in and rod caps are torqued down. Time to clean up the oil pump pick up and get the pump installed.
I also need to assemble the heads and get those ready for paint/install.
There probably won't be any progress this weekend with the predicted low of -6* plus wind chill. Even though I have a heated-ish garage, I don't think that's a battle I'll win.
We'll see.
03 Mercury Marauder- 63k
Originally posted by SVT98t View PostAll the pistons are in and rod caps are torqued down. Time to clean up the oil pump pick up and get the pump installed.
We'll see.
Good work, let's hurry up and do burnouts here.__________________________________________________
Listen here, fucko.
I have a propane heater.
I don't think it'll do too well when the temps are supposed to be 50 degrees below freezing this weekend.
Fuck, it'll be back in the 30s on Monday.
Ordered the last of the needed gaskets and a new timing set. I should be making some good headway tomorrow and through the week.
Ok, finally back out in the garage. It's been cold as shit, plus I've been working overtime.
Now it's time to get this rolling.
All the parts came in. I'm hoping to have the heads assembled this weekend.
I also need more propane.
Sent from my LGLS740 using Tapatalk08 Lincoln Navigator L - 233k
Driver side head is done. Awaiting paint.
Passenger head still needs to be done.
Progress is being made. It should be ready for timing crap by midweek.
Hopefully, it's going in next weekend.
Driver side head is cleaned and primed. It will be green tonight. Passenger head will be cleaned and primed tonight.
Grabber green yo' heads!~David~
BOOM!!
This thing might actually be installed this weekend...
Wasn't this thing supposed to be installed "this weekend" 6 months ago?
It's so awfully ugly, I love the fuck out of it.__________________________________________________
