The 93 GM "Tank of Justice II" (TOJ2)
    Can you smell the baking on engine paint yet?
      So, I fucked up
      Yup. I fucked up.
      When I put the timing chains on the motor, I used my paint marker lines on the cams, crank, and timing chains as a reference. I put them on when they were on the old motor. So in theory, they should have gone on perfect. I did the same thing in the Town Car and it worked perfectly.
      Onwards to a few weeks ago.
      I said I had a timing issue. I was right. The engine turned over and turned over. Then I hooked up the battery to turn the motor over a bunch and prime the oil pump for a start. Then it sounded like it skipped timing(metallic noise) and then it stopped rotating.
      I found out why.
      I took the cam shaft out, and three of the eight valve springs were fully extended, and I could push them back down with my hand.
      Uh oh.
      I FOUND THEM!!!
      I took the head off and found the issue. Luckily for me, I already had the right camshaft removed when this all went down.
      Cylinders look good. there's a few marks in the pistons and heads, but nothing to serious. Plus, this isn't going to be a performance build.
      So I set the timing THE RIGHT WAY last night. It turns over great now. NO issues.
      I found a ton of different ways to set timing and other bullshit.
      There is a super simple way of setting timing on a 2V with NO timing tools.
      I'm making that write-up now and will sticky it.
      Back to more "big steam".
      08 Lincoln Navigator L - 233k
      03 Mercury Marauder- 63k
        well fawk. that's a lot of carnage for not much damage.
          You shit yourself when this all went down? I would tossed up the white flag and opened up the ford motorsport catalogue and dropped some pretty pennies to not have to deal with that again.
          Glad it all worked out. Building engines can be scary if you are not one hundred percent sure in what you are doing.
            You really ought to try a different engine family. Seems you and the modular are not the best of friends.
              or their such good friends that they play pranks on each other?
                I got a valve cover on. And some timing cover accessories too. I still need a non-CVPI oil filter adapter.
                Anyone have one? I don't have time to go to a yard.
                  Progress.
                  Finally.
                      Start the fucking thing already lol. Anticipation...
                        I think he's on the "one part per month" program.
                          The junkyard run from ScottFest was a resounding success.
                          I scored a dipstick tube, stupid oil filter adapter, oil cap, and ,
                          An 02 LX Sport ECM, fuel injectors, and engine harness.
                          There will need to be some decent modification done to the engine and transmission harness, but it's all here.
                          Work shall commence in September.
                          Sent from my LGLS740 using Tapatalk
                            You got an oil cap instead of a 710 cap? You know that negates the cop chip.
                              Shit. I better throw that out then.
                              I needs me a cop chip.
                                Also... the LX sport PCM will expect PATS input... you no gots that.
