Stop telling the secret solution.
The 93 GM "Tank of Justice II" (TOJ2)
Removed the other shock. Also cut both exhaust pipes past the mufflers.
Ready to remove springs and carry on!
03 Mercury Marauder- 63k
hurry the fuck up, still gotta finish the rauder for SF!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!__________________________________________________
Originally posted by SVT98tIt has air ride. I've disabled it since I've been jacking it up and down.
Springs are out. Replacing the rear brake line that goes from the left to right side tomorrow evening.
Might prep the new gas tank for green paint.
Originally posted by SVT98t View PostSprings are out. Replacing the rear brake line that goes from the left to right side tomorrow evening.
-ryan s.Chris - A 20th Century Man \m/ ^.^ \m/
It pretty much is. Just a couple minor setbacks, that's all.
Didn't get into the garage last night, because I wasn't feeling well, but since I'm off tomorrow, I can say out late in the garage and get shit done!!
Gotta get that brake line in, then start the install of the new shocks and coil springs. Prep the tank for green and maybe solder up the sending unit harness.
Woot.
The tank's stuck on traffic cones and someones nabbed the rear tires!2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
It has upper and lower control arms, as you can tell by my premiere MS paint skillz.
Installed wagon springs, kyb Gas-A-Just, And reinstalled the calipers.
Ready for gas tank mania tomorrow evening. Maybe put the rear sway bar on, drive shaft, and "maybe" start it up this week.
Then I can turn it around in the garage and start removing le motor.
Woot. Woot.
Installed the gas tank tonight.
Its probably never coming out again.
Going to wire it up and install fuel lines tomorrow.
It May move under its own power on Saturday night....
Its own, very sick and unhealthy power?
Where's this alumni engine at__________________________________________________
Originally posted by SVT98t View Post[ATTACH]42629[/ATTACH]
Yup. It moves. And is very sick.
Now, on to the motor.
-ryan s.Been there, done that.
My Cars:
