The 93 GM "Tank of Justice II" (TOJ2)
    I still drove it 18 miles home like that.
    08 Lincoln Navigator L - 233k
    03 Mercury Marauder- 63k
      Damn - you've got those pawn shop size balls!
        I could keep driving it because #yolo, but I won't.
        I'll probably take it for a few more romps up and down the street to see if I can blow it up.
          Just be careful in case out of pure spite, it puts a hole or two in the oil pan.
            That's ok with me.
            Sent from my iPad using Tapatalk
              We had a truck at work sound like that, ran fine, didn't smoke at all, just made a lot of noise and was a bit low on power, but had good oil pressure and nothing was leaking. New block/heads and it runs great, same engine but new runs so much smoother and stronger. Now I can't wait to replace the tired 305 in my truck with a new 350 with headers and a tune, gonna be sweet.
              Mount a dash cam when you drive it so we can all watch the glorious boom.
                So, I finally got that spark plug that was stuck in the #7 cylinder out. Now it's time to install new rings, and put new valve seals in and get this motor back together.
                I won't be powder coating the block. The only thing I'll powder coat is the timing chain cover. I need to get this motor built, and I'm sure it'll end up as a 4v in the Town Car eventually.
                So I have some work to do.
                  New rings installed. Coolant passage is drilled and filed.
                  And I weighed everything today.
                  Old Ironside: 148.6 lbs
                  Aluminum madness: 74.4 lbs
                  That's a savings of 74.2 lbs. And it's much easier to move around.
                  Actually, I can pick it up and put it in the engine stand without much struggle.
                  More to come soon.
                    Wow. That's amazing Mumford.
                      That's what's holding me up with my Suburban. I want to permanently fix the lower intake leak issue with the Marine Vortec 350 intake, but it's cast iron like the block so it's heavier than the stock intake. I have to chose between less weight or reliability, and leaning toward reliability, since I can have it tuned when I fix the issue so that'll make up for the weight gain.
                        Annual State of the Tank Address
                        It was a good year. Not a ton of driving, but I did catch up on a TON of maintenance that I've put off. Ending mileage is only 225,038, with the start mileage of 220,621 for a total of 4417 miles.
                        Not too bad considering it didn't move for 5 months while I was deployed. It's currently sitting due to some awesome knocking. I mean, its hilarious.
                        (and I still drive it down the street once a week)
                        Now, onward to,
                        "The List"
                        This is the list of stuff I wanted to get done:
                        - Swap a Teksid block into the PI motor. Yes please, I'll take a 84 lbs reduction in weight.
                        - PI Torque converter to match the flywheel. It's a good thing there's one in my basement.
                        - Run all the new brake and fuel lines.
                        - fix the damn fenders
                        - paint the car. Two tone.
                        - powder coat the 17"s and get new rubber for them
                        - new springs and suspension bits.
                        - rebuild the front end.
                        - replace the rear speakers
                        - eco-mods; panel the bottom, weight reduction,etc
                        - fix the random no-start issue.
                        - beat John at ScottFest
                        - paint the damn thing. Maybe....
                        Here's what was accomplished:
                        -NEW! Brake and fuel lines!
                        -REPLACED! Left front fender!
                        -PAINTED! Like a boss. 17 cans of spray paint!
                        -NEW! Front suspension!
                        -REDUCED! Weight. Peace bro.
                        -FIXED! No-start. PCM harness and shit repaired.
                        I'd say that's pretty F'n good.
                        Things I would like to accomplish:
                        -Finish building the Teksid PI motor.
                        -Get new rubber for the summer tires
                        -Class 3 trailer hitch
                        -Tune?
                        -Drive the piss out of it.
                        Have a great year!!
                        Wish me luck.
                          I forgot to add that I need to repalce the fuel tank, and that I installed Steeda under drive pullies as well.
                          I'm sure I've forgotten something else.
                            awesome
                              installed the pistons today. Slowly getting there.
                                I drove it two miles. Down the road, then turned around.
                                Yup, it still works.
