Wow. This weekend has been a blur.
Moog sway bar end links are in. I powder coated the brackets.
Then did spark plugs. Tell me, do think #5 had any issues?
Put in E3 plugs and a set of MSD StreetFire wires that Summit and Jegs says will not fit Crown Vics. Liars. These were only $40 as well.
Also did a coolant flush, installed the correct green t-stat housing. And fixed the fan to boot.
And fixed the negative terminal. It was loose. So I installed a terminal shim. Hmm, thinking about installing the PI intake this weekend. We'll see.
I couldn't install that belly pan. It did not fit. Front lip was about 4 inches too short. Hmmmm....
The Tank runs geat now.
Ka-pow!
Ka-pow!
