The 93 GM "Tank of Justice II" (TOJ2)
    wow, what the hell just hap.... oooooo, i see what you did there lol
        Originally posted by SVT98t View Post
        Testicles.
        That is all.
        A guy is visiting his Jewish friend. As they prepare to leave for lunch, the Jewish man appears to make a motion of a cross over himself. The guy says "I didn't know Jews crossed themselves."
        The Jew replies, "Who's crossing themselves? I'm making sure I have everything... spesticles, testicles, watch, wallet"
          Ok, here's a few more pics and some narratives.
          Before pics:
          This set is from the 99-04 Mustang GT's.
          For the Aero's, they require 1/4" spacers in the front, and 1.25" adaptets in the rear. The big issue with the rear is that the axles on Aero's are 2" shorter than Whales.
          Always torque the adapters to spec.
          This is the first wheel installed. Just showing a difference betwern the styles.
          I did have to grind about 1/4" off the tips of the studs in the rear. They protruded through the adapters,which is no good. The rims must sit flat on the face of the adapter.
          The tires are 245/45 R17 ZR on all four corners.
          The ride is extremely smooth, and turning is easy and smoothererer.
          Highway cruising is effortless. And these wheels are way lighter than the outgoing setup. I'm going to weigh them next week and see what the difference is.
          Until next time...
          08 Lincoln Navigator L - 233k
          03 Mercury Marauder- 63k
            How was the drive all the way to nyc to get the wheels looks good
              I was visiting the inlaws near Skippyville, so it wasn't that bad. Just under 2 hours to NYC from there.
                Before pics:
                Until next time...
                Looks nice, but how fucked up is the speedometer with that wheel/tire combo?
                  Planning to replace/repair the driver's side fender that the Caravan hit?
                  '79 Continental Town Car
                  '90 Crown Victoria LTD
                  '94 Crown Victoria
                    Speedo is not F'd up. It's the same as it was before.
                    Not gonna fix the fender, unless I come accross something sweet either up here or during ScottFest.
                    Just rocking and rolling. Tie rod assemblies should be going in tomorrrow evening.
                      Holla:
                        nice... and a well lubricated crossmember. as all Ford/Mercury vehicles tend to have.
                          I also found out that the idler arm is shot. So, time to acquire parts and probably go rebuild the front end next weekend.
                          Blarg.
                          It will take a while to do. I have to take off the control arms and such, strip it, powder coat them, and install it.
                          It should be nice.
                            Idler arm is ordered and on the way.
                            Yea for RockAuto!!
                              Lolz. "Compact Only"
                                Compacts aren't really compact anymore lol.
