Thank you so much dude! I painted it as it had a few imperfections in it. Looks great! Anyone notice anything weird in the one pic?
My Vicky
I know what I'm supposed to be looking for, but you told me already. I see it now with both pics for contrast.86 Lincoln Town Car (Galactica).
I see and know it as well, but I will shut my mouth.~David~
He loved mine so much, that he needed a pair of his own.__________________________________________________
Originally posted by SVT98tIt has air ride. I've disabled it since I've been jacking it up and down.
looks good... did you silver paint the accents or was that already done?
I see a power antenna switch and a premium sound head unit... but they may have been there long time....Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
i see 79 crown vic dash trim.
Update on the Vic. Kinda oldish but hey. I don't really pop on here as much as I've used to. Rewind a few weeks back to set the mood.
Drivers side tail pipe rotted away to the point where it fell off of the muffler. The muffler, being stainless, was unharmed. So I figured the other wasn't too far behind. So I went to a local muffler shop and had them bend and install new tailpipes. 224 dollars and about 2 hours later I got new pretty properly fitting tail pipes. Pics to follow whenever I feel like it. :p
Stainless pipe?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
An update for you guys. I recently completed an EDIS conversion for the car. EDIS, for those who are not aware, is the ignition system that the 4.6 (till 1998), and the 5.0 explorer used instead of the distributor. As of now, the car is running off of a modified 4.6 TownCar ecu calibration. check out the video!
need something to support the front end of that coil pack bracket. I can see that vibrating and cracking off the back feet eventually. Wouldn't need to be much, just something to make sure it doesn't start flapping. Or you need a grinder to remove said un-used dingus so it doesn't look like parts are missing.
That BMW sensor is pretty slick. Beats the pants off the radiator anal probe method.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Postneed something to support the front end of that coil pack bracket. I can see that vibrating and cracking off the back feet eventually. Wouldn't need to be much, just something to make sure it doesn't start flapping. Or you need a grinder to remove said un-used dingus so it doesn't look like parts are missing.
Nice, I'm glad you finally announced this, you should do a writeup and make a sticky. Definitely in uncharted territory. It seems to rev up quicker than before? That rev limiter sounded nice. I want to see how the different tables and multipliers look compared to the GUFB.
Thain- I have a radiator anal probe laying around in the garage from the maverick, if that's what you're into-Phil
