Holy thread ressurection Batmang! I put a new passenger front door on the car. From an 88 Grand Marquis, got rid of the ugly trim those post facelift grand marqs have and swapped over my wing vent window! The car now has all new dew wipe material installed by me as well. Car got all new battery/charging cables due to a horrible voltage output at idle from the 3g. Which also turned my coolant into a battery and made my POS radiator spring a leak. That is now replaced with an oem replacement tank. Would've gotten another aluminum one, but I wasn't paying that much, nor did I have the time to wait to get it (being that the radiator got replaced yesterday, and scottfest being friday). As you've noticed as of late, I haven't been posting much here. And even less frequently do I post pictures of what I do to my cars. For those of you who are going to Scottfest 2014, you'll see the car. For those of you who aren't, check the threads...
My Vicky
Looking forward to see the car and hear whats up with you.~David~
Any updates with le Cobra intake???
03 Mercury Marauder- 63k
Last I heard from John is that his steering box took a dump and he is currently planning on the PI steering box swap. Once Ivan is back from vacation ye ol cobra intake job will commence.~David~
Yeah steering box pissing fluid everyhere when I turn. Gotta fill it every time I go to drive it. Huge discoloration in the driveway where it's been leaking. Box is coming from rockauto. Should be here wednesday hopefully. Or someone is going to die.
bottom seal failure, or line failure ? I thought you had replaced that box at some point ?86 Lincoln Town Car (Galactica).
So I did a little research today, since it's raining and woke up too late for junkyard run. The proper steering shaft pieces can be found from a 95-02 Panthers. F8AZ3B676AA that's the part number for the shaft, I guess it supercedes the previous part numbers? Granted I only need the one piece off of it for the new gear box, but can anyone confirm that for me before I go through the trouble of pulling a shaft from an older car (if I can't find any 98-02 panthers).
John this is the piece I put into my car.
I went to the yard on tuesday and got a box lower steering shaft, and swapped over the new coupler via a new rag joint. The steering box came in yesterday and I installed it today. As everything in this car it gave me stupid issues that were prolonging the finishing of the job (steering shaft not lining up, lines not threading in, hoses not coming off of the power steering cooler). But in the end, I got a very tight and responsive steering system. And a plus is that the steering wheel is still for the most part level. Thanks to all of you guys who helped me to get this project done!
Yay! I need to see pics of the lines in that mess of abs stuff.~David~
Originally posted by 87gtVIC View PostYay! I need to see pics of the lines in that mess of abs stuff.
