How far off was the MAF transfer function? I know its not exactly right, but I'm curious how wrong it really is.
My Vicky
Originally posted by gadget73 View PostHow far off was the MAF transfer function? I know its not exactly right, but I'm curious how wrong it really is.
Originally posted by gadget73 View PostA Moates Quarterhorse is a tuner that allows you to change the programming of the computer. Its approximately similar to the twEECer.
Do you still need a certain ECU (with the tweecable J port) or can any of them work?sigpic
Originally posted by 1990LTD View PostDo you still need a certain ECU (with the tweecable J port) or can any of them work?
ON AN EXCELLENT SIDE NOTE!!!!!!!!!
I finally fixed the Open Loop to Closed Loop Transition.
Turns out, that when I did the engine 2 Augusts ago, I plugged the O2 sensors into the wrong connector for the main harness. Which resulted in the signal coming from Bank 1's O2 sensor (Passenger side) was actually relaying it's signal from Bank 2 (Drivers side) As the O2 sensor relayed these signals to the computer, the computer tried to correct for it. While the one bank stayed the same, the other bank became way lean, or way rich. Causing the back firing, hesitation and such that I've had since I put the engine in the car.
Nice! Gotta love simple fixes.
I could have sworn I suggested checking that. I know I checked it on my car when I was chasing problems with it.86 Lincoln Town Car (Galactica).
you should send your spare HPP to live on a farm up north. it would be much happier there.sigpic
