My Vicky
    need help on removing a spindle assembly on a 1999 grand marquis i cant get the lower ball joint to free. i need pics and exactly step by step to remove. it i know the top one had a bolt that secured it on but i dont see a bolt for the bottom ball joint. what is holdin it on there. it wont budge from smacks with a hammer.
      remove the nut and the cotter pin, make sure the shock is still in place. hit the spindle hard with a big hammer to release the ball joint stud
        If you got those ball joint forks, use them. I use them to get the tie rods off as well. I tried using a hammer on Putter Project, but they're (spindle and ball joint stud) rusted together.
          i got a 12 pound sledge hammer that i will pound them with tommorow up at harry's. that should break them free.
            Well Matt succeeded and yesterday dropped off the spindles, hubs, upper control arms and the JBL head unit yesterday. And in return I gave him Vicky's old engine (which needs some TLC before it'll ever run again). A parts list of stuff to get new and from the yard. Some stuff for his SEFI swap.
            Took Vicky to the diner yesterday so me and Matt could eat, it was his treat *I love free food haha*
            Forgot to mention that I also added an Autodimming rearview mirror with a compass. It is completely wired up including the reverse mirror shut off (the mirror undims in reverse at night).
            I got two decent used ABS axles (thanks Scott and Thain) for the disc K code rear end, and scott ordered me a bearing kit for the guts of the differential.
            Thanks to the help of Scott, Ivan, and Larry for helping me get the extra clutch added to my carrier.
            Now all I gotta do is replace the bearings, get new axle bearings and seals, and reassembly can start. Then I can put it in the car! I'm looking forward to that since the howling bearings aren't getting any quieter.
              I gotta get some trunk carpeting that actually stays where it's supposed to. I guess that's another thing to add to the to do list.
              I need a set too. If you come across an additional clean set, I would be happy to take them off of your hands. Name your price, I suppose.
              You go to the JYs alot more than I do, and these cars are more common where you guys go.
              Excellent forward progress on the car.
                I hear ya. Though shipping that stuff would be a bitch. So if you're coming to SF I could return the favor from back in '08 with the exhaust pieces haha!
                I'm wondering if '88+ vic trunk carpeting is the same, since they are more common in the yards around me in Jersey.
                  anytime mang glad we had a good time. come up to my place when your free.
                    hey John, where did you tap that reverse shut off wire for your mirror? I knew the mirrors were capable of it but didn't know we could do that with our cars.
                      Drivers side kick panel, taped up in a harness, a black wire with a pink stripe. That's the backup light wiring. There's also a connector under the dash. But I wasn't feeling that ambitious...
                      In other news, if you've been following other threads of mine, you would know that I have harvested an ABS system from a (figured it out today) 1993 Mercury Grand Marquis. 98% complete ABS wiring harness (including fuse box), brake pedal assembly, hydraulic control unit, brake booster and master cylinder. Granted, the ABS will not be installed until after big brakes. I may install the harness just so I can have the fuse box, because I'm tired of the damn clusterfuck on the starter solenoid.
                        Sexcellent!!!
                        I got the side clears in the mail from Pete today! I put them in the nice bezels. And then put them back in my room. I don't think I'm gonna install them until I get the car painted.
                          Pics Of Clear Lenses
                          Here we are!! Enjoy
                            Nice John.
                              Originally posted by 87gtvic View Post
                              nice john.
                              MINE!!!!11111111111 mwuahahahahaha!!!!
                                Things to come...
                                I have a huge erection right now. And it's because of these right here!
