oked/Tinted Headlamps & Corner Lamps Installed. (DUW)
    Finally found some time to install the tinted headlamps and corner lamps I ordered over a month ago.
    Before installation, the lamps were treated to 2 coats of Klasse AIO and 3 coats of Klasse Glaze for protection.
    I also had to trim the corner lamps' weather stripping as it was too long.
    As others recommended, I installed the alignment tabs from the original OEM headlamps to ensure proper headlight projection.
    Before:
    Comparison:
    Obligatory engine shot:
    After:
    I purchased the tinted headlamps and corner lamps to compliment the tinted tail lamps and reverse lamps.
    The entire set of pictures can be viewed here.
    Thanks for looking.
    The 2003 Marauder 300A F.I.T #003
    The 1998 P71 Jinbei. SOLD!
    The 2001 P71 (Flying Snow).
    Lord Vader, your headlights have arrived...
      Very nice! They work real well with that color.
      oh...where's your engine cover man?? :p
      '95 Ford Bronco XL -
      sigpic :rebel:
        kickass...
          does tinting the lights effect the headlight output?
            Looks badass, especially with that color man.
            Nick
            88 Colony Park LS
              I've never been a big fan of the engine cover, hence its abscence.
              The tinting does diminish the light output but a headlight wiring upgrade kit was already on the the to-do list.
              Thanks for the kind words, gentlemen.
