Originally posted by Tiggie
View Post
I thought the pillar lights had burned out at first, but while checking in the trunk, I noticed the C-pillar accents use a light tube to illuminate the accents. It has to be properly dark to see these operating due to the design.
Anyway, a good number of hours got dumped into this car, and a few left for tomorrow. Found some very amusing things done over the years, like the fact one valve cover had red RTV attempting to seal it, the other had a very petrified cork gasket. Those got some new FelPro PermaDry units. The clone 2150 had much of its vacuum hooked up wrong, adjusted wrong, and the A/C throttle kicker is just MIA. No worries, it probably won't be around too long, I'll explain further on. Replaced the very dead 45 year old shocks with some new KYB Gas-A-Justs. New rear wheel cylinders, brake booster, and master cylinder fitted. Old master cylinder had what looked like mud in the main reservoir, and the rear brake reservoir was dry as a bone. New P215/75R14 tires fitted. Installed new NGK spark plugs and wires. Oil changed with some high zinc 10W-40 and FL-1A oil filter.
Tomorrow will be getting the carburetor dialed in, sorting all the vacuum lines out, resealing the rear axle cover, inspect the EGR valve, remove the smog pump that presently goes to nowhere, and maybe checking to see if the A/C can hold vacuum. Then we can take it for a test drive!
Now with regards to the carburetor, why would I toss a 2150? I'm not sure how good this clone unit really is and how much I trust it long term. I have a 500 CFM Carter AFB handy with a Ford kickdown linkage, so fitting a dual intake on the engine and popping that up on top probably wouldn't be the worst over the wheezy stock cast iron intake. I'm not here to make this car some rocket ship, but I think letting it breath a touch better wouldn't be a terrible thing. I also believe the stock air cleaner will fit over that unit, so with the exception of a careful eye, most folks wouldn't notice much different under there.
